update on my B18C1 problem.
You might remember my probelm from here https://honda-tech.com/zerothread?id=104340
Well I took the valve cover off and turns out my timing belt is loose! Could that make the sound that I described or is the sound responsible for the belt being loose? I checked the belt like 5000 miles ago and it looked new. Isn't there a tensioner pulley on that Timing belt drive? Could that be making the sound?
Also I went to try to get the broken studs replaced at NAPA and they don't have them. Does anyone know where to get them besides a dealer?
the studs that go through the valve cover and into the head but then have a smaller size for the grommet and nut for the valve cover.
and they do sell these neat little pager things you hook up to your keys in case you lose them
chill out and have a beer man
ok.
I found my keys and the car made the sixty mile trip to my friends garage without any valves touching any cylinders
I got my valve cover off and my timing belt is definitely loose. How can I adjust the tensioner and make sure it is not too tight?
BTW: thanks for the beer but i had some Vodka last night instead
roadsqueegy95
15
Jun 7, 2012 09:22 AM
bdmlilburn
Jul 24, 2011 07:54 AM
axtran
May 14, 2006 09:55 AM
