smog obd0 to 0bd1
Old Nov 3, 2004 | 10:54 AM
evo45's Avatar
Default smog obd0 to 0bd1
The car is an 89' civic DX hb. It has a jdm B16A. It is running on a p28 with
full obd1 conv. Conv harness is JDMShit, p28 is stock, has dc jdm header w 2.5
collector, 2.5 hiflo carsound cat, b series injectors (no resistor box), new dist. cap
and rotor, new aem short ram. timing for some reason set at 19 btdc. Passed all
visuals only need to pass sniffer here are scans of the two attempts. Thanks in
advance. after first attempt used sea foam and added new ngk spark plugs. during second attempt ref told my brother felt like it had a misfire.
first attempt
second attempt
Modified by evo45 at 1:23 PM 11/3/2004
Old Nov 3, 2004 | 11:23 AM
mmuller's Avatar
Mad Scientist
Default Re: smog obd0 to 0bd1 (evo45)
your running a b16 with a stock p28?
Old Nov 3, 2004 | 12:13 PM
tgreaves's Avatar
Default Re: smog obd0 to 0bd1 (mmuller)
Good god.. They look under your hood to make sure everything is right in CA.. That sucks.. Since your failing the idle test maybe your running to rich/lean at idle but running correctly when cruzing..
Old Nov 3, 2004 | 03:12 PM
evo45's Avatar
any help appreciated
Old Nov 3, 2004 | 03:25 PM
hondaguyef's Avatar
Retard the timing a few degrees and bump the idle up to just under 1000 RPM. Make sure the cat is warm and disconnect the fan if the ref will let you. PM me for more info. When I lived in CA I worked @ a smog shop and we got many swapped cars ready for the ref so that they could pass legally.
Phil
Old Nov 4, 2004 | 07:57 AM
evo45's Avatar
Default Re: smog obd0 to 0bd1 (hondaguyef)
pmed thanks
Old Nov 4, 2004 | 07:03 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evo45 &raquo;</TD></TR><TR><TD CLASS="quote">pmed thanks </TD></TR></TABLE>
Nothing recieved?
Old Nov 4, 2004 | 07:45 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Retard the timing a few degrees and bump the idle up to just under 1000 RPM.</TD></TR></TABLE>
I was going to say raise the idle to 1075 and also retard the timing 3 deg. Out here the max rpm for idle test is 1100. I failed at 750. Idle was raised to 1075 and it passed. Fuel pressure at 42 psi (idle), b16a, and oem cat from 88 dx.
Old Nov 5, 2004 | 03:13 AM
hondaguyef's Avatar
Default Re: smog obd0 to 0bd1 (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
Alot of the ref's and smog tech's will hassle you if the idle is over 1k. Most of them go by whats on the smog plate under the hood. 750+/- 150 I think?
Old Nov 5, 2004 | 04:13 AM
drdisco69's Avatar
And wouldn't you want to advance the timing, to start the combustion sooner? Thats what I did when I had to pass my cars.
Man I'm glad I don't live in CA...
Old Nov 5, 2004 | 04:40 AM
rsbad454's Avatar
Default Re: smog obd0 to 0bd1 (drdisco69)
did you give it a tune up before you took it down there? not sure if hi flo cats are good? what is your fuel pressure? if it indeed has a mis then that will cause a rich condition. maybe injectors are bad...
Old Nov 5, 2004 | 07:39 AM
evo45's Avatar
thanks, should i lower the timing to stock setting 16 or 14? any other suggestions
appreciated
Old Nov 5, 2004 | 08:42 AM
rsbad454's Avatar
i thought they checked timing and if it was out of spec they would fail or adjust it? i would run good fuel and change the oil......
evo45
Jul 22, 2005 02:51 PM
evo45
Sep 30, 2004 11:17 AM
Nameless RB26
Apr 19, 2003 06:07 PM
CarlosF.
Jan 10, 2003 02:48 PM
