Setting Valves?
very easy after you do it once, just make sure you take your time when your turning the motor over to each cyl. ( best thing you can do is get a haynes manual for your motor or car. got mine at pep-boys)
Adjusting valve lash is adjusting the gap between the top of valve stem and the rocker arm. Get a book and it's not too hard. I did mine last Sat. Doesn't take too long.
DreamSpeed
Jul 31, 2001 09:36 AM
