Setting Valves?
Setting Valves?
is there a good site for setting valves on the dz16z6 sohc out of a 094 si? i need to know where on the cam lobe i need to set it to please help
Re: (EG_Jefro)
very easy after you do it once, just make sure you take your time when your turning the motor over to each cyl. ( best thing you can do is get a haynes manual for your motor or car. got mine at pep-boys)
Re: Setting Valves? (EG_Jefro)
Adjusting valve lash is adjusting the gap between the top of valve stem and the rocker arm. Get a book and it's not too hard. I did mine last Sat. Doesn't take too long.
DreamSpeed
07-31-2001 09:36 AM
