shift linkage install question
Old Oct 23, 2004 | 01:18 PM
xZeler8's Avatar
Default shift linkage install question
I am getting ready to install the shift linking in my del Sol. Is there a particular method to getting the pin in where it connects to the tranny? Thanks guys.
Sean
Old Oct 23, 2004 | 02:14 PM
doublejz's Avatar
Default Re: shift linkage install question (xZeler8)
just get the holes to line up and push/beat (nicely) the split pin in.
Old Oct 23, 2004 | 02:21 PM
sleeping GIANT's Avatar
Default Re: shift linkage install question (doublejz)
use a hammer to tap it in, book says to always use a new pin.just something to think about!!!
Old Oct 23, 2004 | 02:59 PM
Honsu's Avatar
ahhh the beyotch pin. just get a roll pin punch and tap it in. basically same way it comes out
Old Oct 23, 2004 | 04:48 PM
xZeler8's Avatar
Default Re: (Honsu)
you know what size punch to use? i've heard 8mm, but i can't find metric punches anywhere...what size would that be in standard sizes?
Old Oct 24, 2004 | 07:03 AM
doublejz's Avatar
Default Re: (xZeler8)
just use whatever fits the diameter of the pin, you don't want to use something that fits inside due to the fact that it will expand the pin while trying to go in, which may be impossible to then push in. Just use a hammer and hit it in, its gonna have to be hit kinda hard, but don't use a sledge or slam the hell out of it. The punch really isn't need, but is needed for removal. I learned to use a longer pin then necessary so when i have to remove it later down the road, i use visegrips and clap on the extra length of the pin and whack the vice grip with a hammer (comes right out) <-- just something to maybe consider
Old Oct 24, 2004 | 07:28 AM
t0p_sh0tta's Avatar
Default Re: (doublejz)
The punch needs to be 8mm and non-tapered.
Old Oct 24, 2004 | 08:15 AM
EK9Greg's Avatar
You can go the getto way. use a nut and bolt. MOST GETTO
Old Oct 27, 2004 | 05:22 PM
xZeler8's Avatar
Default Re: shift linkage install question (EK9Greg)
thanks guys...i have the new pin...i'm just going to go at it with a bigger hammer...
Old Oct 27, 2004 | 06:12 PM
boostedcivicsir's Avatar
Mr. Badwrench
get a 5/16 roll pin punch. tape the pin to the punch. it will be better on the knuckles. thats the way i do it.
Old Oct 27, 2004 | 07:56 PM
CRFAB04's Avatar
Default Re: shift linkage install question (boostedcivicsir)
if u have an air hammer with the tapered driver that works a lot better than beating the **** out of the pin
Old Nov 3, 2004 | 08:56 AM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xZeler8 &raquo;</TD></TR><TR><TD CLASS="quote">you know what size punch to use? i've heard 8mm, but i can't find metric punches anywhere...what size would that be in standard sizes?</TD></TR></TABLE> 5/16 and 1/4 works nicely!
thundernutz
Sep 27, 2009 04:22 AM
z6hatchboy
16
Aug 6, 2009 07:59 AM
JDMSol626
Jul 14, 2005 11:25 AM
slowpokesi
May 11, 2005 11:36 PM
immortal
Feb 16, 2002 08:27 PM
