hey a lil help hesitation
Old Oct 5, 2004 | 05:29 PM
blackccoupe's Avatar
Default hey a lil help hesitation
hey guys i got a 94 civic i just put in a 96 dx motor used my dx manifold and stuff and my 94 dx ecu when i punch it it hesitates real bad and then gets real choppy like but when i turn the car off it's stops until i punch it again, if i just ease the throttle its ok doens' t hesitate what do u think it could be ? let me know guys
Old Oct 7, 2004 | 08:32 PM
Default Re: hey a lil help hesitation (blackccoupe)
noticed i'm leaning out when i floor it but what coudl cause that ?
Old Oct 8, 2004 | 12:26 AM
Katman's Avatar
if your using an OBD1 DX ecu, you should be having IACV problems...because the 96 DX (Y7) motor uses a 3-wire IACV...
You throwing any check engine lights?
Old Oct 8, 2004 | 07:15 AM
Default Re: hey a lil help hesitation (Katman)
oh i used my odb 1 ex manifold so the plugs match up
Old Oct 8, 2004 | 10:26 AM
1bad-eg's Avatar
Check your tps and map sensor wires. Make sure they are not crossed.
Old Oct 8, 2004 | 11:07 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackccoupe &raquo;</TD></TR><TR><TD CLASS="quote">oh i used my odb 1 ex manifold so the plugs match up</TD></TR></TABLE>
hah, gee thanks for mentioning this in your original post chief!
check your ignition timing?
Old Oct 8, 2004 | 11:42 AM
JDMotive's Avatar
Im having a very similar problem with a obd0 b16a into an ef that I just built for a customer car.If I ease into the throttle than itll be ok,but if I stomp on the pedal it tries to do.Im thinking it may have something to do with the ignition timing,though the cam timing is dead on.Its not throwing any codes.
Old Oct 8, 2004 | 05:09 PM
Default Re: hey a lil help hesitation (JDMotive)
hmm also i noyiced my voltage drops to like 11 volts too what woudl cause that got an new alt didn't help ?
Old Oct 9, 2004 | 05:45 PM
anyone
Old Oct 11, 2004 | 07:41 PM
ok guys when i floor my car the a/f reading up all the way to 20 lol it leansout real bad what would cause this any suggestions welcome
Old Oct 24, 2004 | 07:03 PM
anyone have any ideas really need to fix this could it be any sensors, i don't get any check engine lightst or nething
turbochargeb18c
May 27, 2006 08:18 PM
98civicdude
Nov 30, 2004 03:08 PM
daniel89civ
Oct 16, 2003 04:20 PM
daniel89civ
Oct 15, 2003 08:22 PM
civicracer1993
15
Feb 25, 2003 06:55 PM
