Leakdown test results
Timing belt broke at idle due to a rag getting sucked into the cam gear and jamming (yea i know it was stupid but i need to know how stupid)
Leakdown Test Results
1-76%
2-66%
3-10%
4-86%
Ok i have the snap-on leakdown tester, the way i did it was hooked up the air line to the inlet hose and got the gauge to zero %(100psi) then hooked up the outlet hose to the hose in the spark plug hole and watched the gauge...............someone please tell me i have royally messed up
1-76%
2-66%
3-10%
4-86%
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herde1724 »</TD></TR><TR><TD CLASS="quote">.......someone please tell me i have royally messed up</TD></TR></TABLE>
you did......mess up your motor.
yea..........to my knowledge the valves were closed ................the timing belt is not on at this time so i am just rotating the crank and cams separately
and you're positive you had the piston at TDC for the particular cylinder?
Where was the air escaping....out the intake, out the exhaust, into coolant or into crank case?
i am not positive where the leakage was occuring which tells me that i did something wrong and when the belt broke i heard no valve collision with the pistons another reason for me to believe i fucked up
hey man if ur on the computer still and can get on aol that would be great i really need some help with this **** i have a turbo kit on the car now waiting for this **** to be worked out so it can be tuned
well slapped on a new head today...........gotta love a 100 dollar complete head (try that with a vtec motor)...........the old one was fucked new head yielded 4% leakage across the board
boosting this weekend
getnasty
Mar 24, 2010 10:47 AM
dplatt
Dec 31, 2002 01:24 PM
