vacuum ?
Old Jun 9, 2009 | 10:36 AM
turbo-crx's Avatar
Default vacuum ?
If the timing was out of wack alittle, would it cause it to have low vacuum reading on the boost gauge? I did the 1-2-1 shift at the track and thought i bent some valves, but i did a compression test and it was fine, but it got to dark to check timing to see if it had jumped or not.
Old Jun 9, 2009 | 01:25 PM
turbo-crx's Avatar
Default Re: vacuum ?
anyone?
Old Jun 9, 2009 | 02:06 PM
VTECJUN's Avatar
You should do a leak down test, that will determine if you have any bent valves. The motor will definetely have less vacuum if the valves are bent.
Old Jun 9, 2009 | 02:25 PM
turbo-crx's Avatar
if the compression was perfect across the board, shouldnt i not need to do a leak down test?
Old Jun 9, 2009 | 02:31 PM
turbo-crx's Avatar
the car does not smoke or have any sort of misfire. I even put like 200 miles on the car since this has happened. That's why im leaning toward jumped timing hopefully.
Old Jun 9, 2009 | 02:38 PM
SrT4_OwNeR's Avatar
your timing shouldn't have anything to do with your boost gauge. What exactly is the gauge doing?
Old Jun 9, 2009 | 02:41 PM
SrT4_OwNeR's Avatar
Oh wait your asking about the vac back pressure.... It's quite possible.... But if your timing was out of wack even by a tooth you would be able to tell... Check for boost leaks?
Old Jun 9, 2009 | 03:21 PM
turbo-crx's Avatar
what does vacuum actually tell you about the motor?
Old Jun 9, 2009 | 04:18 PM
SrT4_OwNeR's Avatar
What exactly is your car doing and is it doing it only under boost?
Old Jun 9, 2009 | 05:07 PM
turbo-crx's Avatar
its only reading 10 inch of vacuum, as where before i did the 1-2-1 shift it was reading like 20 inch of vacuum.
im confused. the compression is perfect. im making full boost(15psi) it doesnt smoke or anything.
Its just not reading proper vacuum and thats it.
Old Jun 9, 2009 | 05:12 PM
amimaxima's Avatar
the gauge is reading proper boost but not proper vacuum? do you have any vacuum leaks?
Old Jun 9, 2009 | 05:21 PM
jjspec's Avatar
Sounds like slightly bent valves. Just had a car in the shop like that. Need to do a leakdown test to make sure so it doesnt burn any valves. Good luck.
Old Jun 9, 2009 | 05:31 PM
turbo-crx's Avatar
thanks man. im doing that next.
SrT4_OwNeR's Avatar
The only thing I can think of is check your vac lines going to your boost gauge then check your lines from your wga just to make sure there is no leaks... That kinda stumps me too bro... Just check your lines.... Also what kind of bov do you have?
Old Jun 9, 2009 | 06:18 PM
boostedcivicsir's Avatar
Mr. Badwrench
a compression test is not a leakdown test. as stated above, you can have some slightly bent valves that can cause low vac. and also if your timing is out of whack you will have low vac also.
Old Jun 9, 2009 | 06:39 PM
fmedgsx's Avatar
Line up all the timing marks and if they are all on then progress with the leakdown test.
Old Jun 10, 2009 | 04:33 AM
turbo-crx's Avatar
if they are "slightly" bent. how much power does that rob you of?
Old Jun 10, 2009 | 07:42 AM
fmedgsx's Avatar
it wont necessarily rob you of power. The compression loss is what is robbing the power and with out knowing how much "slightly" is refering too. It is going to be hard to say.
Old Jun 10, 2009 | 07:47 AM
96 GSR-T's Avatar
thats irrelevant, bent valves need to be fixed.
Old Jun 10, 2009 | 11:18 AM
turbo-crx's Avatar
thanks for the input. new itr valves are going in this week.
stan xx
Aug 28, 2015 04:29 PM
getnasty
Mar 24, 2010 10:47 AM
memorybox
May 13, 2009 01:01 PM
loc_yaj
Apr 12, 2008 06:45 PM
herde1724
13
Sep 28, 2004 06:38 PM
