doing a compression test, need help
Old Sep 12, 2004 | 01:47 PM
2k1 SSM GSR's Avatar
Default doing a compression test, need help
i don't need help with the actual compression test, i know how to do that...
my question is, my gsr's timing belt tensioner failed causing the belt to become loose. the car can still start and run at very low rpms with the belt hitting the valve cover.
i'm doing a compression test to see if i bent some valves.....question is, can you do a compression test on a motor with the timing beit on by a hair? will it read accurate results? or should i go and replace the tensioner and belt, then do the test?
i really need to do the test before, that way i can replace the valvetrain while the belt is off.
Old Sep 12, 2004 | 02:21 PM
Jet Black's Avatar
Default Re: doing a compression test, need help (2k1 SSM GSR)
As long as the valves will close at the correct time, the result will be accurate.
What I'm worried about is you say the belt is on by a hair? I'd be afraid of it snapping during the test and you bending some valves
Old Sep 12, 2004 | 02:26 PM
Jet Black's Avatar
you way want to consider a leakdown test instead
Old Sep 12, 2004 | 02:45 PM
quikrpm'z's Avatar
Default Re: doing a compression test, need help (Jet Black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">you way want to consider a leakdown test instead</TD></TR></TABLE>
he wouldnt be able to do that properly either.
Old Sep 12, 2004 | 03:31 PM
BlackDa9's Avatar
Default Re: doing a compression test, need help (quikrpm'z)
Id suggest replacing the belt first, just to be safe..then go from there
Old Sep 12, 2004 | 03:48 PM
Default Re: doing a compression test, need help (BlackDa9)
ok well i did the test...
240-260-240-240
they are consistent, so i'm happy. i don't think i broke/bent anything. think a new toda timing belt and new tensioner should solve my problems.
Old Sep 12, 2004 | 03:59 PM
milo's Avatar
'glad the motor is not hurt
Old Sep 13, 2004 | 11:43 AM
Jet Black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikrpm’z &raquo;</TD></TR><TR><TD CLASS="quote">
he wouldnt be able to do that properly either.</TD></TR></TABLE>
How so? A leakdown would be less risky since he's turning the engine manually to lign it up to tdc...and it would reveal allot more info about the engine.
Old Sep 13, 2004 | 12:18 PM
the car is at acura to see if they will cover it under warranty.
stan xx
Aug 28, 2015 04:29 PM
RockLee`
Oct 29, 2006 03:43 PM
jccigt
May 12, 2006 08:59 AM
jvtec95
Apr 14, 2005 04:29 PM
dplatt
Dec 31, 2002 01:24 PM
