View Full Version : Wheel and Tire
- MHT wheels? cant find any info or pictures
- Weld Prostar on 5th-gen. Prelude?
- Non-tapered (?) extended lug nuts for skinny lug nut holes
- can some one identify this wheels
- where to get wheel spacers?!
- HELP! 92 lude RR tire offset
- 15x6 with slight stretch
- fake project kics neo chro lugs?
- Name of these wheels?
- 2003 Civic EX Wheel Covers Japan vs USA/CAN
- rota circuit 8s what lug nuts?
- enkei bronze paint
- Why doesn't anyone make STAINLESS STEEL Lug nuts?
- VX wheels on my 96 DX hatch
- What style Motegi wheels are these?
- Does width matter for rims?
- Em1 rims?
- offset question??
- 215's on a EM2?
- max tire pressure?
- Which tires are best?
- 94 del Sol steering tugs to right and left
- Gimme your HONEST opinion of these wheels... i can handle it
- What are these volks worth?
- 5 lug Question on em1!
- Civic SiR + 14x6 wheels ... Which tire size?
- wheel offset question
- Offset for Accord LX 1995?
- Drag dr-44 fitment
- tire pressure mysteriously went up?
- Thinner Extreme Summer tire or Thicker Ultra High Summer tire, and tire diameters
- Hoosier 225/50/16 drag radials anyone use these?
- What rims are these?
- ES2 tire help!
- 97 Civic tire fit question
- If the wheel fits you must submit..yes.
- Ls Webs Aluminum
- Need some rim Id help.
- need technical help with wheel fitment on my eg
- The Wheel That No One Knows!
- Help??!! What are these rims??!!
- what wheels to put on midori green hatch
- My current Wheel/Tires setup
- 17x7.5 w/42 offset on eg hatch???
- My Racing Hart 3 piece Rebuild thread!!
- Anyone know where to buy Team Dynamics pro race 1
- What size tires
- 96 Civic 15x8 +25 Fit?
- 99 Civic DX DD Wheel/Tire
- Need help asap,
- Help ID these oem Honda wheels. Thanks
- Need help picking out wheels...
- What's a good wheel size for EK coupes?
- Fitment confirmation
- Someone please help me ID these old Konigs!
- Question(s) on a 275/50/15 drag radial
- what enkei rims are these?
- rims xxr 527
- Nitto NT01 input
- which bbs's are these
- Is it safe to plug this hole?
- Dipping HX wheels??
- drag DR44
- Will LS MESHIES FIT STOCK EJ8
- Need help choosing tires
- unidentified honda rims?!
- Best affordable summer tires
- what color rims should i get?
- Can I get my rims "bored" out?? PICS INSIDE
- dunlop direzza dz101 vs yakohama s drive??
- Loose lug nuts out of the blue...
- Volk valve stems
- Yet another "what wheels are these" thread.
- s2000 wheel fitment: 18x8 18x9 et42
- Stance Mindset on 88 CRX
- EK vti fan blades
- Nice color wheels for Electronic Blue EG?
- offset after lowering
- 215/50/15
- 98 civic 4x100 to 4x114.3
- what are my racing harts worth?
- what rims are these?
- BBS R's
- 949 Wheel fitment
- 225/50r16 vs 255/40r17
- what size 16" tire will fit my ef hatch?
- Where to find steelies?
- 96 Spec ITR Center Caps
- Any recommendations of what kind of spacers I should get ?
- 185/65/14 vs 185/70/14
- Opinion on Toyo Proxes
- Ways to remove heavy pitting from aluminum
- Need some help with Wheels!
- 2000 civic si wheel question
- Remus or 5Zigen?
- which wheels a better buy on a Lada Priora?
- Wheel security
- 16" 205/45 all-weather advice
- fitment question
- Can someone tell me?
- Possible to disable TPNS sensor?
- Discontinued Toyo Proxes T1R...need new Tires!
- 245/45R18
- Need cheap spacers
- Bent aluminum rim
- What tire size is the best?
- Does anyone know what these rims are?
- Question about Drag tires and street tires
- How to tell wheel roll?
- Does anyone know where to get colored wheel locks?
- New tires soon...
- Wheel brand help!
- A-DISK, O-DISK, T-DISK????
- best tire size for 13s
- Da9 on low offset ?'s
- Y49 CRX Wheel sugestions
- Finding a 195/50/14
- Aluminum Hub Rings
- Wheel and Tire spec Help Please!
- Need Help for Picking Tires
- EM1 with xxr 513 15x7
- S2000 wheels
- 205/50/15 road tyre vs 195/50/15 semi
- Snow Tires
- 205/40/16 vs 205/45/16 -- Why?
- Lets Talk Tire Sizes
- 15mm spacers on gsr fat fives
- Tires
- Is there Work RZs center caps??
- so cal winter season new tires azenis????
- OnlineTires.com still has issues. Awaiting my order now from TireRack.com.
- what rims r those
- BAD Inner Tire Wear (But "Good" Alignment)
- Looking for reasonably priced tires for 96 civic
- Can someone identify these wheels
- Winter Tire Question
- Tire help
- Can someone please tell me who makes these rims?
- Tire advice - 07 Accord cpe 205/60R16
- Can you put 15" rims on a 2008 Civic LX?
- Weds TC-05 Centre bore size 16x7
- would theses xxr's fit my 98 civic hatch
- R/H 3 pc rim hardware question... 12pt bolts or allen bolts??
- Fitment help please.
- What wheels are on this VW Bus?
- Tire Size / Wheel Combo safe?
- Best Tire Size for 16" Wheel when Lowered.
- Need help on what color to get for work equip 03
- What tire sizes & brands are you running on your ef?
- Work wheels question
- Help buying these wheels
- New rims, what tire size? Calling all stanced/stretched/slammed/flush gurus***
- Blizzak vs. Others
- axis og oldskool +25 offset questions
- Any 225/50/16 daily drivers here?
- Need help! would it fit? what tire size?
- 93 lug pattern question
- Wheel fitment !!!
- Mugen wheel lug nuts, can someone confirm their material?
- White or Black gloss steelies?
- Wheel and tire
- summit racing drag rims
- 205/40/16 vs 195/45/16
- Identify these wheels please
- How to tell if Desmond Evo Regamasters are real
- Interchange wheels between Civics
- Can anyone identify these? Grape rims
- what is the lug pattern on these and size
- Need help identifying wheels
- Spacing and Offset Issue.
- Legality of TPMS
- Anyone heard of Triangle Tyre tires?
- buddy club rims
- Please Help Identify this wheel or at least how to search for it
- How do I plolish my ls webs?
- re30
- strange wheel noise
- What offset and width are my TE37's? Pics inside, help please!!
- Tire size for my 07' Accord
- Wheels for EJ8
- Can Somebody Tell Me What These Are???
- stripped 9-spline lug nut key and lug nuts
- Can Anyone Tell Me Which Rims These Are. Please!
- 17x7.5 +20 wheels on an eg
- What kind of wheels are these plz help
- help identifying(& photoshopping) old Enkei wheels
- konig rollers
- Good Tires
- noob question need help
- 195/55r15 vs. 195/60r15
- show your painted wheels
- What is the best way to strip my wheels?
- Is the brand Drag Wheels any good?
- does size matter?
- Wheels more FLUSH!!??
- Falken RT-615
- Blox lug nuts fitment.
- HellaFlush on 2005 Civic 4-Door
- will any 18 inch tire fit on any 18 inch rim?
- 25mm spacers, ARP extended studs.
- tire size question. for s2k
- Sticky DD tires for ocassional autocross
- negative offset please!
- Yokahoma S drives Vs Nitto NT450 ?
- Offset question
- drag tires 17"
- Lug nut gram light 57 "15
- Identify this Konig Rim Please!
- PIC REQUEST!!! 5Zigen Del Sols
- Black Rims With Chrome Lip
- best tire size for 16x8 +15?
- ek9 ctr 4 lug rim help
- Could someone help and tell me what rims these are?
- CIVIC SI '01 (EM2) 15" RIMS OFF SET?
- CIVIC SI '01 (EM2) 15" RIMS ON COROLLA '01 OFF SET?
- Help me out, quick question about some wheels!!
- nitto neogens!!
- Pleasse Help
- I'm getting bored with my wheels - suggestions
- Lug Nuts
- To all "Stance Experts" i need your help
- Need some suggestions, Maybe even some schooling...
- Wheel options! Lighter vs wider?
- Wheels on a cd6??
- Smaller tires = speedometer and tachometer reading higher?
- Integra staggered wheels fitment 16x7/8
- 195/65r15 winter tires!?
- 24 inch tall tires?
- What is interchangeable w/ a 185/65/r15?
- 185/65 vs 185/75?
- You can teach an old wheel new looks!!(old dog new tricks)
- What rims are these? Drags what?
- Diamond racing wheel set up?!
- wheel id anyone?
- Can anyone id these rims
- wheel id please.
- 15" daura sports
- Summer and Winter Tires, what to do in the fall and spring
- bbs wheel guru's please chime in!
- Old school ls mesh rims
- Help me identify this rim
- 15x8 +32 tire size help?
- wheel offset and lip
- Trade steelies for this?
- What rims are these and what are they worth?
- OEM steelies needing new lug nuts
- HX's rims -- Tire choice
- 93 si 15" slips need help with tire descion
