View Full Version : Wheel and Tire
- lug patteren looks funny
- Rim Size????
- Rate tread left on these azenis
- nexen tires????
- Civic ej1, 16x7 subzero ET45. What tire size you recommend? :)
- Advan RGs
- powder coat CHICAGO area
- Tire pressure monitor
- Is this possible....from +35 to +40 offset
- Does SSR make these in 4x100?
- bolt pattern inquiry
- JSpcl's Rota knock offs of the Rsz-r on EG 15"
- New Mounted Wheel Air Leak
- Anyone running Wilwoods on 16" Rotas?
- help with hx rimx/tires
- Which high performance tire for a 14x6 wheel??
- Tire Help
- Suggestions for replacement tires (05 Accord)
- Falken Azenis rt-215 or the rt-615 ?
- Help, opinions/pics needed!
- Center Cap Question
- 5-lug conversion on CB-7.......Little Help please
- Anybody bought wheels from memoryfab?
- AZENIS RT-615 tires
- 25in slciks.. on 13x7.5 wheels
- max rim size for 1996 honda civic hx
- 205/40/16 fit too scretched?
- what kinda wheels are these?
- DRAG DR-16 WHEELS?? GOOD VALUE??
- What are some light wheels for the track....
- Pic Request: Polished Slipstreams on Red EG
- Whats the differnece?-- Rota slipstreams vs. Nippon F-2
- Question about RAYS extended lug nuts..
- Cheap cool rims?
- any experience with Dunlop SL Direzza
- Bronze wheels on White Integra?Pics Plz
- anybody running 15X6.5inch rims with a +32 offset?
- Q/A 215/50/17 vs. 225/45/17
- 6.5 or 7 wide?
- I'm rubbing help..
- velox vx-8's?
- Plz help me pick a new tire
- Super Star Racing... is it SSR??
- offset on 96 civic hatch
- DUnlop Direzzas in 14?
- Wheel Width effect
- Good wheel repair shops in Florida
- rims for 98 dc2
- fender rolling tool renter?
- Lenzo "drag" wheels on the street.
- 13's on an EF with integra brakes??
- tire pressure
- Have you ever seen this Caliper Cover?
- Need help: Need rims/tires for my car! Motegi???
- Prelude w/ 17's
- valve stem on tires help quick!!!!
- got new rims but may need repair
- Spoon SW88's
- Need an UHPAS tire, any suggestions?
- bfg drag radials 215 is it too big???
- What Center Caps to Use on Mugen MF10L's
- pic request: white ej8
- Restoring the shine on OEM wheels
- H caps for Rota
- Stock lugnuts on Te37's
- Tire pressure 205/40/17 '00 Civic?
- Quick Question About Wed Sports
- how good are the Falken Azenis RT-615 in the Rain?
- Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R
- 215 size tire??
- LS webs but not sure what size drag radials will work?
- 225/50/15 BFG on 15x6.5?
- mugen cf48's
- ??? 14x7 wheel???
- ITR wheels on a 04 CRV?
- What Rims are these??
- kosei k-1 racing rims 16" center caps?
- What tire size are recommended for 16' rims
- looking at 5x114.3 honda OEM rims...what options do i have ?
- pciture request - 5th gen white accord with bronze 95 ex rims plz!!
- Pic Request-99 Civic w/ Bronze Si wheels
- Hub centric ring
- gram lights 57c
- best wheel and best price wheel for accord
- Bronze Lug Nuts!!!
- Any place still have 205/50/15 Azenis 215???
- Need honda center caps for 15" gt3 rotas.
- Ugliest Rims you've ever seen...Post your pick...
- does anyone know where I can find these 15x8 or 15x9
- Mugen M7 or Rota J-Mags.
- Name that rim
- 15x8 4x100 +40 12.8lbs
- 16" Kosei K1's... do they come in 4x114.3?
- discontinued wheels
- axis hiro's
- What purpose does this serve?
- 15x7 vs 15x6.5 any advantages
- Falken Ziex 512 in the snow?
- Bfg drag radials
- SSR Stickers
- What wheels are these???
- Rota c8 problem
- falken vs kumho
- tire/wheel combo 98 civic
- pic request...
- Are Desmond RegaMaster's different than the Spoon SW388's?
- quick question about removing center caps
- 17" tire size
- azenis vs. goodyears
- Konig Heliums
- Azenis suck...
- Rota Circuit 10 Bronze Color
- 99-00 Civic w/ Rota Boosts (pic request)
- 204/40-17 tires with 17x ??? sized rims?
- WHATS THE BEST LOG NUTS FOR MY RIMS CAN'T BE STOLEN
- JDM ITR 16" wheel offset
- Toyo Proxes T1-R...anyone have experience with theese?
- What rim is this??
- bald tire ?
- RIMS TIRES SIZE/FRONT REAR, PLEASE HELP
- Some help with possible alignment issues
- About to acquire VX wheels
- Freshly refinished 2k rims in graphite metallic
- Are the 205/50/15 Azenis "wider" than other 205/50/15s?
- Wheel offest question.... Help!!
- Special pricing on 205/40/17 tires at Tire Rack
- Rim Repair??anyone??
- 55 or 50??
- IS WIDER BETTER?
- Drag radials - 205/45/15 vs. 205/55/14 -> which size is better?
- Rota slips...question about centercaps
- 4 16" advan three spoke copies, pa.
- Possible to weld a rim?
- Wheel powder coating question
- RH center cap help
- Hankook W404 anygood?
- Rays lug question
- Where to get these centercaps?
- Racing Hart C2
- How long until flat spots develop?
- wich tires for summer and what ones for track?
- Name these Wheels..
- Opinions on BFG's
- Checkout this lug wrench
- What company makes the best BBS look replica ?
- accord pic request
- Opinions needed: Hankook Ventus Rs2 Z212 vs Falken Azenis Rt615
- drilling 4x100 wheels to 4x114
- Where can I order TWO Rota Grids?
- sprint hart cpf 5 lug??
- Just picked up a Honda CRX 90 w/13'' steelies. Please recommend an action
- Tire wear...Out of nowhere. Toe or camber issue....or worse?
- +45 Offset on Accord?
- 215/40/17 Azenis on 97 Civic. Too wide?
- 215/45/17 on a 17" x 7.5" wheel
- How much do HX wheels weigh? Thinking about getting some...
- Enkei RPF1 15x7 only comes in +35 and +41 offset ?
- Bent HX lip
- need a pic please
- Help...need opinion on JMAGS!
- painting brake drum totorials
- Konig Heliums
- info request...
- will integra center caps fit si rims?
- 15X7 WHEELS
- Fitment of 17x7 wheel on Civic EK, Offset?
- Pic Request: Prelude with Rota Boosts
- good non-track low dust brake pad?
- will 15x8 rota slipstream fit around wilwood 11 inch kit
- Pic Request
- Wat tire size so that no rub?? Need ur Opinions!!
- what offset if perfect for 96 accord 4dr?
- 275/50/15 drag radials, will they fit 15" slipstreams or is it too wide?
- What are some good recommended brands of wheels for the US market?
- Need help on lude rims
- Wheel an tire combo question!!!!!
- Aircraft stripper safe on mugen mr5s?
- Any ideas for nice USDM wheels?
- Review of Blizzak LM-25
- BBS Wheel Question 13"x6"-Calling all of you BMW guys
- Need help with acquired SSRs (GP-0)
- where can i get rims like these?
- Post reliable sites to buy wheels.
- E25 offset on a crx
- which wheels are there??
- tire size
- sw388 lug nuts help?
- 18 inch aerospeed with tires
- Trying to identify aftermarket 17's on the Integra I just bought
- 17" Drag Radial options for 06 Si
- Best choice tire and dealer for what I'm doing?
- 205/45/15 Nitto 555R's...good size?
- Gorilla vs. Muteki Lug Nuts
- GSR Blades+200 Bucks For Rota Gt3
- Can it be repaired?
- Disappointed in the Tire Rack
- pic request: 16" Black Rota Slicks on Silver EK
- What offet to get?...
- What is a good set of 15" $400 wheels?
- GUNMETAL WORK EMOTION CR KAIs wheels for sale
- pic request: 16 in wheels stock height on 205-45 tires
- 15inch Rota MSR rim weight?
- Rim like the Wes Sort TC005
- gsr and LS brakes
- Rim question
- Tire size? Please help
- work cro1 wheels ?
- Wheels or Brakes?
- durability of an aluminum 15"x10" wheel (all purpose)
- Wheel weights (balancing) options for GSR blades? inner / outer mouting?
- FS: 16" Enkei HOles Gunmetal polish lip
- what you guys think?
- best deal on lugs?..
- Difference--> Standard vs. High Speed wheel balancing??
- oz wheels
- How durable are FLIK wheels?
- Oem Wheel locks for 95 Civic
- new Jmags...... on a hatch??
- Question on buddy club p-1 sf wheels
- 4 x 120 mm bolt pattern (non existent?)
- tires in irwindale
- hankook ventus r-s5?
- best wheel lock?
- need tire+ suspension advice (DC4) thanx
- Volk wheels, short or extended wheel lug nuts?
- Volk GTu's + Black EM1 (pic request)
- Offset question?
- GSR Hammerhead Rubber Choice
- Who makes lightweight 15" Rims?
- different between tires size
- rota j.spl on dc
- Integra rims and tires - 16's or 17's
- 225 45 17
- Quick Tire Question
- The best All Season PERFORMANCE Tires?
- what is your choice of best tire for drag racing
- Need suggestions (pictures preferable): 17", fat spokes, no more than 6
- wheel offsets???
- del sol rims
- Ultra High Performance S Vs. High Performance AS tires....Daily Driver
- 245-45-18 Q
- pic request silver ek pics need idea for rims
- Widest Tire for 95 Civic EX
- Please help identify this Enkei rim
- Opinions wanted pls. TL/CL rims on 01 Accord
- PIC REQUEST: rota grids..on black dc2
- Ek Hatch Wheel pics
- 13x7
- 15x7, 205/50-15 and +35mm, fitment?
- Car Wash Tire Guide Rail - Back Left Wheel Damage?
