PDA
View Full Version : Wheel and Tire
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Please tell me.......
  2. Hard to find tires
  3. EK4 : RE-30 15X7 +35 Face S3 !
  4. What rims are these?
  5. Outside Edge of Tire Wearing After Alignment
  6. different offsets??
  7. dished wheels 4x100?
  8. Volk Racing CE28N. Is it real or fake?
  9. Big tire car
  10. WHEEL FITMENT ON DB8
  11. 2001 civic lx on gsr blades
  12. Broken Wheel Lock
  13. 16x8 rpf1 w/ endless calipers
  14. BBS rs Help
  15. 225/50/R16 on 96-00 Civic?
  16. oz wheels
  17. Dunlop cpr's in white ?
  18. 16x7 with a 30 offset on a 95 integra sedan
  19. Tire Size
  20. HELP me find a set of these!
  21. Tires suggestion???
  22. tire balance issue... anyone seen this?
  23. 2000 Acura EL 5-lug swap - can I use AP1 rims?
  24. Racing Hart rim question?
  25. ARP wheel studs required with drag radial?
  26. What rims are these?
  27. EJ civic, 15x8 wheel question (I did search)
  28. balancing slicks
  29. Tire size selection help - 165/45/15
  30. Moon hubcaps bad for brakes?
  31. Deciding on CCW's
  32. What rims are these
  33. 13 in 6 offset front wheels on ef
  34. whats the biggest tires i can use??
  35. tire size and rim
  36. Tire brand/size suggestions
  37. What kind of wheels are these? HELP
  38. asking for input on wheel choice
  39. Rim Help
  40. Question about paint and offset
  41. Rear tire wearing on the inside
  42. EP3 CTR 17" wheel n tyre options????
  43. Question about offset looking to buy a spare
  44. winter tires
  45. 15x8 +25 w/ 225/50/15 EJ1
  46. Tire ?
  47. RAYS Eng. Experts Please
  48. Another what wheels...
  49. UHP Tires vs. Track/Comp
  50. Best place to buy rotas?
  51. 205/50/15 Summer Tires
  52. Tire size?
  53. What tire size for best traction on r16 rota slipstreams
  54. 215/?/16 on 8" wide wheel
  55. ej6 coupe in desperate need of a proper set of shoes
  56. Diamond racing wheels for drag radials on ef
  57. Desmond Regamaster Evo pricing
  58. ej6 hatch wheel fitment!!!
  59. bolt-on only wheels, what size specs for bigger wheels?
  60. Lenso - VPD - Comp V2
  61. EJ8 Tire Size+ rim size questions
  62. Where do I find tires for these wheels?
  63. Another what wheels
  64. Tenzo R Wheels Good or Bad?
  65. XXR 522 wheels on eg hatch?
  66. Dunlop Direzza DZ102
  67. What wheels are these?
  68. wheel size
  69. Integra Type R 16" fitment
  70. what tires to buy? 175/70/13s
  71. Rim help?
  72. 93 del Sol - will these wheels bolt up?
  73. Ep3 wheel help needed
  74. 2009 CRV Tire size
  75. BBS wheel help
  76. del sol wheel fitment
  77. Gram Lights 57Pro valve stem
  78. Found these rims, not sure if real, can't find info.
  79. Bolt pattern
  80. 205/45-16 recommendation
  81. best
  82. IN NEED OF HELP!
  83. 215/40-17
  84. Leak at the valve stem
  85. Honda wheel idenification?
  86. oem Enkei wheels
  87. mugen cf48
  88. 949Racing 6ULs
  89. Using Spacers - What shouldn't I do...
  90. Ssr type x's
  91. Rotas Grid V
  92. Rim choice?
  93. Sticky-icky Street Tires 20-50-15
  94. Whats rims look better Stance Emotions or Xxr
  95. ruff racing r358
  96. retro rims help
  97. lug nuts please help
  98. Federal 595 or 595 evo tires compared to falkens?
  99. Wheels Offset?
  100. Question about konig heliums and tire sizes
  101. Any clue what these rims are? 690kg via jj 17x7
  102. What Lug Nut Type Is This?
  103. Tyre Size ???
  104. Are these "Enkei" wheels real?
  105. 215/70/15 studded on '02 V6 accord
  106. 91 civic hatch
  107. Honda Civic coupé LSi 95
  108. Can someone help identify these rims?
  109. VOLKS wheels expert
  110. TPMS light still on, Fit, how fickle are they?(tire wasn't flat but over inflated)
  111. what wheels are these? please help
  112. Sherwood Racing wheels
  113. Wheel sizing for track car help
  114. OEM wheel replacement
  115. Anyone know who makes these wheels?
  116. Help me identify my Konig Rims
  117. LS mesh VS. SI wheels?
  118. Enkei j10 help
  119. 215/50/17 vs 215/55/17
  120. Need some help with tire size selection!
  121. deepdish 13x5 or 5.5
  122. 8-9" wide wheels similar to Sprint CPR?
  123. confirm real or fake volk ce28n "8 spoke"
  124. What rims are these
  125. what car are these from?
  126. Tire stretching
  127. Im not lowering my car, what wheels
  128. slice in sidewall? need new tire?
  129. 16" rims on lowered Eg civic?
  130. wheel weights in pdf format
  131. Wheel spacer/hub centric question
  132. Is this wheel suitable for my EM1 ?
  133. help me pickout the 16's
  134. integra da9
  135. Lost Wheel Lock - What are my options?
  136. Billet spike lug nuts?
  137. icw racing wheels any good
  138. Running 18x8's on a 2008 Accord V6 Sedan
  139. Wheel Painting
  140. 89 Ef Si Help w/ Wheels
  141. need help with offset and backspacing
  142. Where can i find this wheel!!
  143. diamond wheels hits calipers
  144. How to go about restoring this rim???
  145. Tire question
  146. Special pricing on select Bridgestone Potenza S04 !!!
  147. CRX Si Fitment question
  148. crx 15x8 question?
  149. F.Y.I. Meaning of Yellow and Red dots on tires
  150. 87 load index 205/50r15
  151. Looking for someone with some Racing hart type C wheels, have a question
  152. Advice on spray painting rims!
  153. Falken A these Falken tires
  154. What tires can i drive to the track? Race... Then drive home on?
  155. What Rays are this ones
  156. Wheel specification help?
  157. Sparco NS2 with extended studs?
  158. Advise on where to find a used tire?
  159. Wheel shake and pulling to right
  160. civic em1 tires question
  161. Will 2008 stock wheel fit 2003?
  162. Wheel Size Question
  163. What should I put on my car?
  164. Little help please, 2000 si wheels on 98 civic
  165. Ordered some Bridgestone RE11a:
  166. Need help identifying wheels
  167. What are these rims?
  168. Need help choosing some wheels
  169. Specific valve stems specs for sprint hart CPR's?
  170. BBS Style Wheels
  171. Enkei RPF1 question
  172. ROTA WARNS OF COUNTERFEIT WHEELS
  173. Best bang for the buck
  174. 99 Civic EX - Tires Rubbing - Noob Alert
  175. Aftermarket lug-nuts on HX rims????
  176. !!!!Wheel experts look in!!!!
  177. how much can these bent volks go for?
  178. 16x7 40mm offset what tire size for 96 ek9
  179. Trying to figure out my offset
  180. New tire size on my 2004 Honda Pilot
  181. 225/45R16 TOYO R888 fitment Integra?
  182. What are these rims?
  183. What are these wheels?
  184. try 2 find wat tires 2 put on my 16s
  185. Rim Size question!
  186. name these wheels
  187. Rare Advans
  188. Where to buy OEM wheel replacement?
  189. 89 civic si backspacing
  190. Are these real? Volk CE28-N
  191. Will these tires work?
  192. Another what wheels thread
  193. fitment on 96 civic coupe
  194. Question about gash on gsr blades
  195. Help identify these Enkei's
  196. Another "Identify This Wheel" Thread + Tire recommendations
  197. Compact spare - mount a regular tire
  198. Tire Size Questions
  199. Is this worth to trade for?
  200. Name These Wheels?
  201. anybody know what kinda wheels these are?
  202. What enkei wheels are these?
  203. What are these rims called?
  204. anodizing removal?
  205. What wheels are these?
  206. wheel spacer size
  207. Wheel ID
  208. Does anybody know what these wheels are called?
  209. wheel fitment - level / pro BOOM!
  210. Winter tires in the summer
  211. What wheels are these?
  212. Question aboutba 17x10 wheel
  213. Right wheel shakes and now squeaks
  214. Question about hub centric rings
  215. 15x7 et25 on eg civic - and no, i don't want "stance"
  216. HELP ME DECIDE
  217. Identify these wheels
  218. Fitment on Enkei RPF1 16x8 +38
  219. Polished wheels stains
  220. Where can i get ccw lm16
  221. giovanna rims confusion
  222. Staggered Wheels on 93 Del Sol S
  223. old topic new question
  224. 16x7 BBS?
  225. rh evolution
  226. Whole wheel barrels...let's find the distributor thread!
  227. Which color should I paint my rims?
  228. Da integra biggest tire I can run??
  229. What size tire should I go with?
  230. thinking on getting allstar-wheels 16x8.25 4x100
  231. Identify these wheels
  232. Rota Slips
  233. Offset on rims?
  234. What rims are these?
  235. What wheels are these
  236. Best wheel for my application?
  237. Help finding the right tire fit?
  238. 17s on 91 crx, help!
  239. Wheel Lock
  240. Quick noob question.
  241. TRIANGLE tires brand?
  242. Rota Jmag rim question
  243. 205 50 15 t1r or 195 50 15 r1r
  244. can someone help me ID these wheels please?
  245. need help on ftire size, asap please
  246. Grams Light question.
  247. Advice?
  248. Will they fit?
  249. cant figure out what kind a rim this is and any comments on how they look? be honest
  250. Need A Wheel ID To Plz!
