Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Spongy brake pedal on '06 TL
Old 11-06-2010, 09:20 PM
BrittK's Avatar
Default Spongy brake pedal on '06 TL
I just replaced the front pads on my '06 TL with Acura pads and now the pedal is spongy and travels further. Before I put the new pads on, the pedal was rock solid. I did one side at a time and there are no leaks anywhere. As usual, the piston in the caliper had to be pushed in to allow the caliper to fit. At a loss and the fluid level is near the max level.
If there was air in the brake lines, what is the proper sequence to bleed them?
Old 12-05-2010, 04:06 PM
BrabusCClass's Avatar
Default Re: Spongy brake pedal on '06 TL
You should not have to bleed your brakes... Did you pump your brakes before you drove on them with the car off? Is your brake fluid reservoir cap on correctly and tight?
Old 12-12-2010, 09:03 PM
wc@acura's Avatar
how many miles u have? there a service bulletin .
swizz977
19
05-24-2011 08:35 AM
namewasdallas
Suspension & Brakes
04-06-2010 08:06 PM
B18Redline
06-23-2002 09:48 AM
Quick Reply: Spongy brake pedal on '06 TL
