Tell Us What You Did To Your EG/EK/Del Sol Today
Old Feb 15, 2018 | 09:05 AM
  #3801
LiteraCola's Avatar
Corvette Forum Member
Default Re: Tell Us What You Did To Your EG/EK/Del Sol Today
I think I'm just gonna stick with drums for the time being.
Transfering the tags to the hatch after work! I can't wait to daily this car! She's got a fresh oil change, new air filter, I'll most likely swap the plugs and do a good Seafoam treatment. She's ready to roll!
Old Feb 15, 2018 | 09:18 AM
  #3802
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
So sweet!
Old Feb 15, 2018 | 02:44 PM
  #3803
tony_2018's Avatar
Fish Twig
driving my civic around, feels super awesome on them turns. feels good creeping by cars on turns
Old Feb 16, 2018 | 04:51 AM
  #3804
mrtay06's Avatar
good morning guys. I have a 95 del sol si with a z6 i love my ride. since i got it i have replaced many parts. rack and pinion swap from power to manual. i will be replacing the axles tomorrow. i relocated the battery to the backside of my driver seat. i have to kill switches, one from my ignition and the other from my battery. i removed all ac components and poser steering ****. next i will be getting skunk 2 lcas and ucas as well as tie bar. im still trying to decided between true harts or skunk 2 full suspension , what do you guys suggest? also on my left fender i did a custom rick and morty comic decal. it came out real nice. i want to get all my suspension parts and drive train replaced before i do any engine work. my third gear grinds so ima run it hard until it gives then i will replace it with my d 15 trans and do a clutch upgrade well im in there. engine wise i would like to change out the pistons and do a lit rebuild before working an boooooooooost lol i would like to turbo the z6 for a little bit until i save up for my b16 swap. also i will be getting 13 x 8 diamond deep dishes after the suspension is complete but not in a hurry .
delsol gang for life ( or as long as possible ) lol
Old Feb 16, 2018 | 05:00 AM
  #3805
B18C5-EH2's Avatar
Former Moderator
Loved
Welcome, mrtay.
I'd start a new, dedicated topic for your questions either in the EG+Civic forum here, or if it's a specific suspension Q try posting in the Suspension forum.
Old Feb 16, 2018 | 12:58 PM
  #3806
Freedo_Civegra's Avatar
Got a front end alignment. Had the fronts right on the money, but had to adjust the rear.
Old Feb 18, 2018 | 05:00 PM
  #3807
Ej1_87's Avatar
Homemade catch can and vented valve cover experiment
Old Feb 19, 2018 | 07:16 AM
  #3808
Premium Member
Loved
Community Favorite
That's awesome! Let us know how it works!
Old Feb 19, 2018 | 08:24 AM
  #3809
civic402lx's Avatar
Installed this last night. Work pretty good i must say. For 30shipped.
https://www.aliexpress.com/store/pro...5cae262bWcZRWY
during daytime its harder to see but at night tis fine.
Old Feb 19, 2018 | 01:18 PM
  #3810
Got me some Integra seats!
Don't say a thing about my dirty shop!!! Dagum old as dirt Suburban left oil everywhere.
Old Feb 19, 2018 | 01:57 PM
  #3811
countrynoob's Avatar
From: Whats Up MN!! But still the middle of nowhere...
I cleaned off the snow to my car and proceeded to throw on a blanket from the roof of the car to the drivers door because wires everywhere. I then reconnected my chipped ecu to my car and sent pics to Hondata/forums.
Old Feb 20, 2018 | 01:36 PM
  #3812
Eddie's Avatar
Master Ninja
Lol thats great nice job.
Old Feb 22, 2018 | 01:57 PM
  #3813
I connected my SRS Light Switch and suddenly, my Hondata is communicating with my laptop again. I'm guessing this may support the idea that ECUs don't go bad from storage?
Old Feb 22, 2018 | 02:02 PM
  #3814
I'm guessing a filer is hidden underneath that "shroud" for the catch can? Just wanted to be sure.
Old Feb 22, 2018 | 04:37 PM
  #3815
Ej1_87's Avatar
It's a baffled filter
Old Feb 22, 2018 | 04:42 PM
  #3816
Ej1_87's Avatar
So far so good.... I'm thinking about using the charcoal canister as a catch can and slapping the baffled filter on top
Old Feb 24, 2018 | 01:10 PM
  #3817
B18C5-EH2's Avatar
Former Moderator
Loved
I swapped out the Neuspeed Bilsteins for custom rate 672F/560R BC Racing DS (Digressive Piston) 30 way adjustable coilovers. Combined with the new trans build with new LSD, 4.7FD and retune that netted me +40whp and torque in the mid-range this thing is ******* insane to haul *** on curvy roads.
Old Feb 26, 2018 | 03:24 PM
  #3818
Eddie's Avatar
Master Ninja
Looking good as always
Old Feb 26, 2018 | 07:15 PM
  #3819
mstauffer67's Avatar
replaced windshield molding
Old Feb 27, 2018 | 09:46 AM
  #3820
civic402lx's Avatar
Began the process of replacing all the bushings with hardrace bushing kit.. everything is unbolt fro. The car, just waiting for the kit to arrive in couple of days. Rear passenger side upper and lower control arm, both had 1 seized bolt to bushing. Had to dremel both ends off the bolt.. *urgh*.. ordered new bolt and nuts from boltdepot.com
Found out needing both front lower ball joint and driver upper ball joint. Passenger inner tie rod is toast. So need to replace that also.. once the kit arrive, it will go shop to get it press old out and new in.. then reassemble will begin. Follow by an alignment.. hoping to wrap everything up by end of next weekend. *fingerscrossed*
Old Feb 27, 2018 | 11:24 AM
  #3821
Dakey Unknown's Avatar
i replaced my fan switch sensor my fan still doesn't work I replaced the temp sensor my temp gauge still doesn't work but if I put a paper clip in fan switch connector the fan works fine tired paper clip for temp sensor still say cold. can someone please help me out
Old Feb 27, 2018 | 07:16 PM
  #3822
civic402lx's Avatar
Replaced both front lower ball joint with sankei 555 ball joints.
pressed out, nkt too old, rear trailing arm bushings. Both side, getting ready for hardrace rta bushing.
replaced inner tie rod with sankei 555 inner rod. Awaiting tie rod dust boot to arrive. Sankei 555 outer tie rod waiting patiently..
slow progress
Old Feb 27, 2018 | 08:42 PM
  #3823
Admiral Beckett's Avatar
Pressed in my new LCA bushings and reinstalled my subframe. Engine and trans will be going back in shortly.
Old Mar 3, 2018 | 08:05 PM
  #3824
Ej1_87's Avatar
Just finished the valve cover and catch can... wrinkle black!! Almost done breaking in the motor and she'll be ready for turbo
Old Mar 4, 2018 | 09:13 AM
  #3825
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Fixed Warhatch's tummy ache. No more has all over my driveway.
