Tell Us What You Did To Your EG/EK/Del Sol Today
Old Nov 20, 2017 | 05:29 AM
  #3601
dsol's Avatar
Default Re: Tell Us What You Did To Your EG/EK/Del Sol Today
Drove my civic last week a few days to work. Was able to find my MPG, currently getting like 21.6. Buddy says it should be higher and suggested I do a compression test. so next chance I get I am gonna pick up a kit and get that checked out. weather been messing with my car time, and now its holidays.
97 civic, ls 5spd with a "freshened" b20 swap btw.
Old Nov 20, 2017 | 07:42 AM
  #3602
B18C5-EH2's Avatar
Former Moderator
Loved
Swapped OEM bumper-to-fender hardware with better **** that won't ever sag like the shitty expansion clips.
****'s tight y0!
Old Nov 20, 2017 | 12:39 PM
  #3603
tony_2018's Avatar
Fish Twig
Jelly
Old Nov 21, 2017 | 06:03 PM
  #3604
gostlyman2's Avatar
****'s tight y0!
What size bolt and nut did you use for that setup? Where did you get it? Been having the same problem with the oem ones.
Old Nov 21, 2017 | 09:42 PM
  #3605
Admiral Beckett's Avatar
Finishing up some welds and giving the subframe a protective layer of paint to prevent rusting.
Old Nov 22, 2017 | 05:29 AM
  #3606
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Dude!
Old Nov 23, 2017 | 10:26 AM
  #3607
subie-squad4's Avatar
Icon4 Re: Tell Us What You Did To Your EG/EK/Del Sol Today
I have a 98 honda civic ek hatchback with a swap motor h22a with a gsr tranny but my driver side axel has slipped off and just comes off everytime i buy stock axels but now im confused on what type of axels i should get could someone please help me. Its a H22a with a gsr tranny
Old Nov 24, 2017 | 08:28 AM
  #3608
BlueSi88's Avatar
Well I didn't do much to mine but add some new speakers all the way around. Full kicker front and rear. Didnt take pics cuz it was late but it sounds better then the blown memphis audios that were in there.
Old Nov 24, 2017 | 06:47 PM
  #3609
loleg's Avatar
Got some new shoes! 02 Si wheels with Riken Raptors (we gets some snow here so I couldn't go with anything more aggressive)
Also changed all fluids (Mobil1 Synthetic 75-90 gear oil in trans and 5-30 in motor)and installed a new master ans slave for the clutch. No more leaky master! This car is awesome, 2 weeks in and I'm really enjoying it.
Coming from an EA Si, i think this car has a bit more power especially down low. Even got 45 mpg on my first fill-up, I thought my fuel gauge was broken it wasn't moving hardly at all, but in 190 miles I used only 4.2 gallons.
Next is the Drums as they're making noise and the brake pedal has too much travel.
Old Nov 24, 2017 | 06:54 PM
  #3610
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Attachment 506442
Not sure where you got to put 75-90 into your tranny.
Should be Honda MTF, Torco MTF, GM Synchromesh Friction Modified or if all is not available, 10w30 conventional (not sythetic) motor oil.
I do not believe I have ever seen any Honda Guru or Honda Tranny Guru recommend any of the normal gear oils like 75-90.
Old Nov 25, 2017 | 01:53 PM
  #3611
B18C5-EH2's Avatar
Former Moderator
Loved
Installed this steering wheel:
Old Nov 26, 2017 | 05:12 PM
  #3612
DELSOLgrrlly's Avatar
Icon5 Re: Tell Us What You Did To Your EG/EK/Del Sol Today
Swapping out in dash electrical harness from o7 del sol automatic. To a manual one. Im so over my head help please
Old Nov 26, 2017 | 05:16 PM
  #3613
97.. Not 07
Old Nov 27, 2017 | 06:57 AM
  #3614
dsol's Avatar
my civic needs this BAD
Old Nov 27, 2017 | 09:11 AM
  #3615
Josh Jackson's Avatar
I’ve been searching the web for about a hour and can’t find a wiring diagram for under the dash someone put a aftermarket security system in and it’s causing problems can some one link me to something that would help patch my wiring back together
Old Nov 28, 2017 | 11:07 AM
  #3616
civic402lx's Avatar
try the12volt.com
Old Nov 28, 2017 | 03:27 PM
  #3617
Chadrad66's Avatar
Nice white hatch, nice MOMA steering wheel. I put a chipped p28 ecu im my EM1 and now car won't start. I think its either bad p29 or I need to do something with the dizzy. Really not sure. I emailed my tuner, so maybe he can give advice. cheers
Old Nov 29, 2017 | 04:31 AM
  #3618
dsol's Avatar
Still getting bad mpgs...starting to think it could be my timing. I don't think I timed it right electronically. Was told there is a 2prong plug that's by the ecu that I need to jump to keep the car from adjusting timing as I time...time-caption. anyways I didn't know that till after I timed it, which did help it run better, but I went back to try and fix my error and I cant find this mythical plug. bad mpgs till I find it. open to suggestions or tips though
Old Nov 29, 2017 | 02:31 PM
  #3619
Premium Member
Loved
Community Favorite
Not sure where the plug is on your '97.
For me it is the plug you jumper when checking codes...
Old Nov 30, 2017 | 05:47 AM
  #3620
dsol's Avatar
and I think its the same on my 97...but there is no plug around there...going pull my battery our next chance I get to see if it never made it through the firewall.
Old Nov 30, 2017 | 05:58 AM
  #3621
egsleepercivic's Avatar
should be tucked up under the dash down towards the passenger side kick panel
Old Nov 30, 2017 | 07:46 PM
  #3622
UsernameRequire's Avatar
I removed my eibach ground control coilovers and a-arms to clean out the nasty cob webs.
Old Dec 1, 2017 | 05:09 AM
  #3623
dsol's Avatar
is it part of the engine harness that comes through firewall?? or part of dash harness?
Old Dec 1, 2017 | 03:28 PM
  #3624
You should probably start a new thread but check this link
https://honda-tech.com/forums/honda-...lists-1901557/
Old Dec 3, 2017 | 09:06 AM
  #3625
speaking of wiring coming through the firewall, that whole harness is just one piece right? I'm to trace mine and just removed the evap and blower, glove box and bar last night on the passenger side. And I can see were it comes through, but it looks like it goes past my heater core. And I'm not too excited to see that. Does that passenger side disconnect at the fuse box under the driver side there? [I already have it unclipped from all the tabs in the engine bay and was ready to bring it through the firewall. So one hacked through the stock harness pretty good...] Also I didn't remove the dash yet. :/
