Si front and rear sway bar setup for ek civic
Re: Si front and rear sway bar setup for ek civic
Are the Si forks required for some reason to use a sway bar?? Or is it that you need them to run the LCA's?
The Front Sway Bar from the Si/CTR mounts at a different location than other 96-00 Civics, thus why it requires these additional two items. The Front LCAs are also thicker where the fork mounts, so other forks will not work and that's why you need those too. That said, you also need a longer bolt to join the Fork and Front LCAs.
SPOONfdEK
21
08-08-2003 03:08 AM
