What would I need to put CTR sway bars on my EK
I'm using JDM ITR 5 lug conversion on my EK. What would I need to use the CTR sway bars on my car. I already did a search and didnt find anything on this topic. thanks
Re: What would I need to put CTR sway bars on my EK (SPOONfdEK)
You would need:
- LCAs
- Forks
- Sway bar
- All mounting hardware
from a CTR or 99-00 Civic Si. I believe they are the same.
- LCAs
- Forks
- Sway bar
Re: What would I need to put CTR sway bars on my EK (EricUSC)
you will need the stuff on this site:
http://beaksproducts.com
1 Post
Re: What would I need to put CTR sway bars on my EK (Gump)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gump »</TD></TR><TR><TD CLASS="quote">you will need the stuff on this site:
http://beaksproducts.com </TD></TR></TABLE>
Only for the rear bar.
Re: What would I need to put CTR sway bars on my EK (fowleryo)
isnt the front 00 si and CTR the same size? 26mm ? except the si rear is like 13mm so the CTR would be much thicker.
i see people use ITR rear on EK's all u need is the si endlinks ?
Re: What would I need to put CTR sway bars on my EK (chameleon)
front anti-sway bar
99 SI = CTR = 26mm
rear anti-sway bar
SI -> 19mm CTR->23mm
with itr rear anti sway bar, you can always drill a hole closer to the middle to put the endlink from the anti-sway bar in.
99 SI = CTR = 26mm
rear anti-sway bar
Re: What would I need to put CTR sway bars on my EK (spoon_ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_ek9 »</TD></TR><TR><TD CLASS="quote">front anti-sway bar
99 SI = CTR = 26mm
rear anti-sway bar
with itr rear anti sway bar, you can always drill a hole closer to the middle to put the endlink from the anti-sway bar in.</TD></TR></TABLE>Si rear sway bar isn't 19mm, it's much smaller than, I think it's 12 or 13mm.
99 SI = CTR = 26mm
rear anti-sway bar
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon »</TD></TR><TR><TD CLASS="quote">wooo copped an SI front swaybar complete on ebay for $28
all i need now is a ITR rear :-x</TD></TR></TABLE>
Complete, as in lcas, endlinks and forks? If so, good deal.
nah i wish, has endlinks and the middle bushings with the bracket, so all i gotta do is get LCA's (bolts from honda), i wouldnt need forks would i ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fowleryo »</TD></TR><TR><TD CLASS="quote">Yeah, you need forks. The si/ctr forks are wider than cx/dx/lx to accomodate the wider lca.</TD></TR></TABLE>
gotcha. now on another subject, the jimfab traction bars says 92-00 civic excluding the 99-00 si, is that because the LCA only has 1 bolt on the front side and the jimfab needs 2 bolts for that adapter?
1 Post
Not sure. It may have something to do with the width of the lca. The bars might be too long or short.. not completely sure.
when you say forks, what do you mean , im using ITR front upper and lower control arms. Is there a after market company that makes a kit for the EK's ? I know comptech makes a good rear setup but im not sure about the front . thanks
1 Post
Re: (SPOONfdEK)
You aren't using ITR front upper control arms. Totally different design than the Ek.
When I say forks, I'm talking about the front suspension.
They are what's fitted to the base of your shock. What attaches to the lower control arm. The civic si / ctr forks are wider to accomodate the larger lower control arm.
When you are installing a civic si / ctr front sway bar, you need to install the civic si / ctr lower control arms, shock forks, the endlinks and the bar in order for it to work properly.
I would stay away from aftermarket for the front. OEM is best imo. Everything fits and nothing rubs. Plus an oem front set is pretty cheap. Usually around $150 for everything.
As for the rear..
In order for you to run a CTR or ITR rear sway bar, you need the following:
1. Sway bar
2. Bushings
3. D-brackets (what attach the bar to the frame)
4. Si endlinks
5. Beaks SRK. This is what supports the subframe. Without it, you run a very very good chance of ripping out yours, seeing that US Eks were never prepped to run anything bigger than 13mm as opposed to the CTR / ITR's 22mm bar.
As for the rear..
1. Sway bar
2. Bushings
4. Si endlinks
Re: (fowleryo)
Is it possible to put CTR rear LCAs on USDM 96-00 Civics? Are there any real benefits to it other than being able to run CTR dampers? I've never seen anyone do it before.
Re: (EricUSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EricUSC »</TD></TR><TR><TD CLASS="quote">Is it possible to put CTR rear LCAs on USDM 96-00 Civics? Are there any real benefits to it other than being able to run CTR dampers? I've never seen anyone do it before.</TD></TR></TABLE>
u got it all wrong buddy, CTR LCA's are basically SI LCA's no difference.
New User
99 SI = CTR = 26mm
rear anti-sway bar
rear SI sway bar is 13mm, 1 mm smaller than the integra's non type R
99 SI = CTR = 26mm
rear anti-sway bar
Re: (chameleon)
u got it all wrong buddy, CTR LCA's are basically SI LCA's no difference.</TD></TR></TABLE>
I said REAR LCAs, not front LCAs. I know that the CTR has different REAR LCAs from all USDM 96-00 Civics and was wondering if it would fit. Notice that if you were to buy JDM coilovers, there would be a set for the EK4 and EK9, and we would get the ones for the EK4 since the rear EK9 dampers won't fit our cars.
1 Post
Re: (EricUSC)
I said REAR LCAs, not front LCAs. I know that the CTR has different REAR LCAs from all USDM 96-00 Civics and was wondering if it would fit. Notice that if you were to buy JDM coilovers, there would be a set for the EK4 and EK9, and we would get the ones for the EK4 since the rear EK9 dampers won't fit our cars.</TD></TR></TABLE>
You're misunderstanding. He was right. The 96-00 rear lcas are the same as the Ek9 lcas. No difference at all. They aren't like the ITRs which have a sort of cup shape.
I used to have EK9 Tein HA coilovers on my 00 hatch.
Re: (EricUSC)
your wrong ,you were read corectly, now sit down
klomast3r
11-05-2005 04:08 PM
