sway bar for ek hb?
sway bar for ek hb?
i have an EK hb and it doesnt come equip with a sway bar(not strut bar)in the front , at this moment im running a SI sway bar on the rear . but i want to know whats a good sway bar for the front ? will the SI ront sway bar fit??
Re: sway bar for ek hb? (Spoon1)
Si front swaybar will fit. IF you use the following parts.
1. Si front forks
2. Si front lower control arms
3. Proper bushings, etc.
1. Si front forks
you are going to need the bar, the end links, lca's, forks(because the lca is bigger) and it bolts right up to your subframe. you have holes for it already. you need the lca's so the endlink has a spot to bolt up to. this set up is really good, i am running si/ctr front and itr rear sway with beaks srk. makes a huge difference.
