Lighting HID/Xenon kits, Retrofits and Associated Topics
Hid Problem when turn on
Old Dec 23, 2007 | 05:44 PM
Ruben19's Avatar
Default Hid Problem when turn on
today i installed my Mcculloch 5000k hid kit .
everything works fine except, sometime when i turn the headlight one side dosent light up. i have to turn the switch off and then on to make it work. The kit came with hid hardness. other than that it works perfect. you think i may have to relocate my ground. only the left side is doing this.
Old Dec 23, 2007 | 06:31 PM
Ruben19's Avatar
anyone
Old Dec 23, 2007 | 07:57 PM
prelude1897's Avatar
Default Re: (Ruben19)
check your grounds and all your other wiring. Also try swapping your ballasts with each other and see if the problem occurs with the other light. If you still have the same problems, it sounds like your ballast is going out
Old Dec 23, 2007 | 08:17 PM
Ruben19's Avatar
thanks
Old Dec 23, 2007 | 10:28 PM
Ek4 life's Avatar
Check your wires, cause I had the same problem and it was my wires......One of the wires isn't connecting?
Old Dec 23, 2007 | 10:30 PM
Ruben19's Avatar
ok
thanks
ill make sure everything is connected
Old Dec 24, 2007 | 10:54 AM
chawski's Avatar
another thing that might be worth checking is your battery. When i have my stereo going for a bit before i turn my headlights on, sometimes i get the same thing. Also, do you have fog lights that are turning on at the same time. thats another time that i get a similar problem. i realize i need a new battery, im just trying to put it off as long as possible
Old Dec 24, 2007 | 06:19 PM
Ruben19's Avatar
i swaped my ballast but still the same
then i fix my ground wire and now is working perfect
mookie86
Lighting
Mar 26, 2009 03:17 PM
dagle
Lighting
Oct 12, 2008 08:33 AM
EJ6_Sedan
19
Nov 21, 2007 10:21 PM
vtek9
Lighting
Nov 14, 2007 12:54 PM
DrewDown
Mar 3, 2007 06:12 AM
