Lighting HID/Xenon kits, Retrofits and Associated Topics
problem with hid
Old Nov 11, 2007 | 11:07 AM
vtek9's Avatar
Default problem with hid
so my hid kit on my integra somethings it flickers off for half a second and turns back on. would you think it's the ballast or is it the bulb itself i might have to change, does anything have the same problem?
Old Nov 11, 2007 | 03:59 PM
eggmygirl's Avatar
* B A N N E D *
From: Running Round At Night In Los Angeles Like A Crazy, Veva Mexco, Veva Mexco
Default Re: problem with hid (vtek9)
i ahd a problem with that too
we've got a ticket from that problem
check the way your mounting your housing
loose wires
Old Nov 11, 2007 | 04:48 PM
operatic's Avatar
Default Re: problem with hid (eggmygirl)
Is it on one side? both sides? Did your kit come with a relay harness?
If it is just one side, then it may be a bulb or ballast.
If you have a relay harness, check all your connections and especially your ground and 12v source connections.
Old Nov 12, 2007 | 05:10 AM
M30B35's Avatar
Default Re: problem with hid (operatic)
most likely the ballast or you have a lose connection. The bulb will not flicker, once its ignited it'll stay on. if it flickering something it preventing it from staying ignited usually the ballast.
Old Nov 14, 2007 | 12:54 PM
denshu's Avatar
Default Re: problem with hid (M30B35)
What kind of ballast do you have? Usually cheap kits do that because the ballast is no good
dc4teg95
Lighting
Feb 2, 2011 03:30 AM
immajackuup
Dec 19, 2008 07:19 AM
spoon-eg
Feb 19, 2005 08:10 AM
