Lighting HID/Xenon kits, Retrofits and Associated Topics
Headlight went dim
Old Jan 14, 2008 | 09:03 PM
CeoStatus0's Avatar
Default Headlight went dim
I have a 98 Civic...
Driving home one night the road looked a little dark. Then at a stop, looking at the rear bumper of the car in front of me I noticed that my driver side headlight was dim. The pass side had a normal output, where as the driver side was on but just very dim (looked like as if it was going to die out like you see a flash light dying out because of batteries).
I drove it the pass few nights and that driver side is still dim... what could it be?
Old Jan 14, 2008 | 09:46 PM
DiRT!'s Avatar
Default Re: Headlight went dim (CeoStatus0)
sounds like a ground problem
Old Jan 14, 2008 | 09:59 PM
CeoStatus0's Avatar
Default Re: Headlight went dim (DiRT!)
how would I go about checking it?
Old Jan 14, 2008 | 10:35 PM
DiRT!'s Avatar
Its found here:
Left headlight : G202 next to the washer fluid and ps fluid reservoirs next to a brown 1-pin connector
Check for corrosion.
This link should help
https://honda-tech.com/zerothread?id=1212147
Old Jan 17, 2008 | 06:24 PM
Decaf's Avatar
ive had that problem a couple of times, try making sure that it is plugged in all the way, ive looked and noticed it was a little loose
Old Jan 20, 2008 | 05:20 PM
CeoStatus0's Avatar
Default Re: (Decaf)
naw, it's def. not the plug
Old Jan 20, 2008 | 06:09 PM
RyanJC's Avatar
Default Re: (CeoStatus0)
Swap the bulbs and see what happens.
Old Jan 22, 2008 | 07:06 PM
b18 hatch mike's Avatar
Default Re: (RyanJC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanJC &raquo;</TD></TR><TR><TD CLASS="quote">Swap the bulbs and see what happens.</TD></TR></TABLE>
thats what i did and it fix my problem
hermtm2
Honda Civic (2006 - 2015)
16
Oct 16, 2009 12:13 PM
frost_0ne
Jan 25, 2009 08:19 PM
otsegolectric
Jul 22, 2008 10:47 AM
Brown-tec
Oct 29, 2006 10:48 AM
slvrcivic97
Apr 12, 2003 11:23 AM
