obd1 in and obd2 how is it done
ok i have a 96 civic dx hatch and i just got my hands on a 95 gsr full swap engine harness ecu and all now i also have a 97 gsr ecu laying around ... now i dnt have any kinda of engine harnes for the civic i dnt know were it got to wen i took the stock motor out so i was going to buy a 96-00 ex vtec harness is this smart wat else will i need to do wiring wise to put this 95 gsr in my 9 dx hatch please help asap help is much appreciated thanks guys....
Seagull Management
Re: obd1 in and obd2 how is it done (williebrenn)
If your using a '97 GSR ecu, get a '96 - '98 EX harness, don't get a '99 - '00 harness, the ECU plugs are different. add wiring for the knock sensor. you'll need an OBD2 B-series alternator, injectors. Convert the OBD1 distributor to OBD2 either by using a conversion harness or change the plugs. wire the IABs, if you want them, this is optional. I probably missed something but thats at least most of it.
Re: obd1 in and obd2 how is it done (94EG8)
can i use 310 cc ijectors from a 2000 si on this i plan to u se nitrious eventually and also there no wireing required for this no pin changes or anything???? Will all the civic plugs fit right on???
Modified by williebrenn at 11:13 PM 8/12/2008
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williebrenn »</TD></TR><TR><TD CLASS="quote">can i use 310 cc ijectors from a 2000 si on this i plan to u se nitrious eventually and also there no wireing required for this no pin changes or anything???? Will all the civic plugs fit right on???
Modified by williebrenn at 11:13 PM 8/12/2008</TD></TR></TABLE>
Those injectors will work fine, no pin changes there, just the other stuff i mentioned earlier.
iight im going to get All thise thing then post again on how to wire the knock sensor and anything else will i need to use the plug from the knock sensor??? On the integra harness??
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williebrenn »</TD></TR><TR><TD CLASS="quote">iight im going to get All thise thing then post again on how to wire the knock sensor and anything else will i need to use the plug from the knock sensor??? On the integra harness??</TD></TR></TABLE> take the plug for the IAB (if you want to wire the IAB) and the plug for the knock sensor from the intergra harness.
ok sounds good def will do do i wire the knock sensor in the spot d6 correct is it only a 1 wire plug or is there a power for it also????
50trimmed
03-07-2011 09:12 PM
