When your swap arrives what should you check for?
Old 02-06-2002, 09:25 AM
EKen9's Avatar
Default When your swap arrives what should you check for?
I just got my swap today and for one thing it came with no paper work (I bought it from a company)also the shift linkage into the transmission has been broken off, is it supposed to be like that? Please tell me things that I should be checking for!
Old 02-06-2002, 09:58 AM
KGAccord's Avatar
Default Re: When your swap arrives what should you check for? (VTECivic2K)
Sometimes you don't get paper work, but broken shift linkage doesn't sound right. You should check sensors, wiring, hoses, oil pan, block itself for leaks or cracks, crank pulley, distributor, and pull the valve cover off to get a look inside.
Who did you buy from?
LisaCivic
14
05-21-2007 08:34 AM
onefastx
10-26-2006 05:41 AM
streetracerof06
08-26-2005 08:32 AM
bubblebackinSI
01-02-2002 07:10 AM
Quick Reply: When your swap arrives what should you check for?
