bought new injectors, need quick help!!
Hey guys i just bought a set of 460cc injectors from an rx-7 w/ a resistor box for my soon to be boosted LS..im having a little trouble w/ these fitting the o-rings right etc...are these even compatible!?(the guy told me they were..) and if so what are some tips you have
Are the seals just a little bit too small to fit around the bottom of the injector? If so, just dremel out the seal until you get a good clean snug fit. That's what most everyone has to do with their aftermarket injectors.
More info from you would be helpful too!
How are the injectors not fitting the seals? Are the injectors too big, and the seals too small? Or is one a square and one a circle?
well, theyre fitting very tight on the o ring seals on the IM like i try to get them in partially then put the fuel injector rail on but theyre not far enough down..so there for i cant get the rail on to slowly tighten the nuts down to try and some what force them dow...ive never installed injectors before and ive asked for opinions from my buddies but it really hasnt gotten me any where..thanks again
