B-Series Front Torque Mount/Bracket for Hydro
Does anyone make or has anyone home made a B-Series Front Torque Mount/Bracket for Hydro trans? Reason I am looking for one is because on my trans one of the two bolt holes on the rear trans bracket broke off so not I only have one bolt on the block and another on the bottom hole of the trans. I am trying to give some help to that rear mount basically. Any ideas guys? I added a picture for clarification (not my actual picture).
Re: B-Series Front Torque Mount/Bracket for Hydro
why not fix the rear trans mount. You really need it.
The front mount is really just to qualm vibration.
You're only option is to get a innovative crossmember and front mount.
But it will transfer a lot of vibrations.
Or buy a front mount and have someone weld brackets to your crossmember.
Cant really fix it a piece broke off the trans case. I think I may have to buy the innovated cross member but the mounts say for cable trans only.
hmm, do you mean the bracket that goes on the tranny for the mount that bolts to the sub frame ties to?
Why not weld a stud and put a nut on it
Or just weld the bracket to the tranny
