question about knock sensor newbie
Old 05-14-2005, 03:39 PM
xtremecrx's Avatar
Default question about knock sensor
well i got a crx with b16a and it started thowing code 23 which i think is knock sensor and i was wondering why is it throwing that is it cuz my engine already is messing up, or just the sensor going bad, and if so how can i check if the engine is messing up, thanks guys for ur feedback
Modified by xtremecrx at 12:20 AM 5/15/2005
Old 05-14-2005, 11:19 PM
xtremecrx's Avatar
Default Re: question about knock sensor (xtremecrx)
anybody with any feedback thanks
Old 05-15-2005, 01:33 PM
Jmunk's Avatar
Well check to see if it's wired, connected. If it's hooked up than it's probally bad, so your gonna need a new one, or go to a chipped ECU that dosen't look for it.
Old 05-17-2005, 11:47 AM
DutchEG6's Avatar
Default Re: (Jmunk)
wich ECU are you running?
if do not have a JDM ECU... the ecu do not have a knock sensor program or hardware in it
Old 05-17-2005, 03:37 PM
xtremecrx's Avatar
Default Re: (DutchEG6)
im running a pr3, i was doing some research and came out to a conversion to an obd1 using p28 and doing the hondata how good is this, any info regarding this change will be greattly apreciante it, and if someone has done this hondata those it really work and is it hard to do it
thanks guys
Old 05-22-2005, 07:49 AM
xtremecrx's Avatar
Default Re: (xtremecrx)
anyone else
adam081904
03-28-2008 07:30 AM
e g - s i x
01-14-2005 11:40 AM
VTECLuDe96
12-22-2004 09:31 PM
servion
07-02-2004 04:08 PM
Spoon_Civic
01-12-2002 07:42 PM
Quick Reply: question about knock sensor newbie
