hondata.. Knock sensor
Old Feb 17, 2003 | 01:35 PM
servion's Avatar
Default hondata.. Knock sensor
When you disable the knock sensor with a 4b hondata system, are you still required to have one hooked up? I broke my KS, and I want to know if I have to replace it even though it's disabled in the romeditor.
Old Feb 17, 2003 | 11:58 PM
servion's Avatar
Default Re: hondata.. Knock sensor (servion)
any hondata gurus with some insight?
Old Feb 18, 2003 | 01:45 AM
sgT's Avatar
sgT
i think even with it disabled in the 2.5 software it will still throw a code.
just use the p28 rom instead.
Old Feb 18, 2003 | 07:13 AM
servion's Avatar
Default Re: hondata.. Knock sensor (sgT)
will a p28 rom work in a p30 ecu?
Old Feb 18, 2003 | 09:08 AM
sgT's Avatar
sgT
i believeso. try it. it wont damage anything if it doesnt. but im pretty sure it does work
Old Feb 23, 2003 | 06:52 PM
servion's Avatar
Just to let you guys know, my p30 map in my p30 ecu with the knock disabled runs fine without a knock.
Old Mar 2, 2003 | 07:08 PM
Rob Dizzle's Avatar
my 95 gsr ecu (p72?) has the knock sensor disabled because i broke it as well.
it is not throwing a code anymore.
hope that helps
edit: I have the S200
[Modified by Bob-DC2, 9:00 PM 3/2/2003]
Old Jul 2, 2004 | 04:08 PM
TurboTeG4's Avatar
Default Re: hondata.. Knock sensor (Bob-DC2)
So im running a 94 gsr with a p72 and im going with hondata s200b with a socketed p28. Is it better for me to run the p72 with knock sensor or the socketed p28 without the knock sensor. WTF is a knock sensor
B Dap
Engine Management and Tuning
Nov 25, 2009 11:44 AM
hothondas
Mar 25, 2008 11:21 PM
shreddinryguy
May 12, 2005 10:53 PM
B18Flip
Oct 28, 2002 05:53 PM
brcivic411
Jul 25, 2002 05:57 PM
