Obd1 b18c in 96 Civic
I am planing on installing my gsr into the 96 Coupe.
Has anyone seen or heard this beening done?? I know that hasport makes a conversion harness for this setup..
What are your thoughts, fill me in, let me know the dealio!!
Re: Obd1 b18c in 96 Civic
lol, believe it or not this has been done a looooong time ago and you dont need any conversion kits or anything like that dude. maybe u should research B-series motor swap more before tackling this swap.
but for mounts and brackets you need the upper driver side mount bracket from a 99-00 Si civic. u also need the rear T bracket from a 99-00 civic Si. u need a front transmission torque mount bracket from any B-series hydro transmission and depending onb if u want to keep your A/C, the A/C compressor bracket will need to be changed. hooookay bye good luck
Well that's good to kno mane. Thanks for the info. Its not my first swap, so I believe I can handle her.
I can just use the obd 1 engine harness ??? The pins at the connector are similar for the ecu??
H-T Premium Sponsor
the obd1 civic and obd2 civic engine harness are completely different
the coversion we offer is you send us your obd2 engine harness and obd1 engine harness. we convert both harnesses into one which makes a plug and play harness for that engine into that chassis
you dont already have a obd2 harness in your car? if you do its pretty much plug and play for the most part, you just need to wire in vtec if your single wasnt
yeah you use the 96 civic harness maybe u might have to swap out sensors but i believe most plug and play but the dizzy you will need a rywire harness and if u have a 3 wire IACV u need converted to 2 wire and IAT plugs are different but you can use your obd2 one..best to convert to obd1 p28 and get a chip.
good info guys.. So no need for a gsr engine harness... I do have the obd2 engine harness. So it dont really matter on the harness the plugs will work for the obd1 b18c..?
asocallocal
04-11-2008 10:28 PM
JDM99DC2
04-11-2005 02:08 PM
