odb1 b16 swap into 96'
I gotta obd1 b16 that I plan on putting into my 96 hatch. My question is if it is direct bolt in or do I need defferent mounts. I'm slightly confused in the matter becaasue I saw on passwordjdm.com a bracket that they said you have to buy if you plan on swaping a b series into a 96-98 civic. Any help is much appreciated.
Re: odb1 b16 swap into 96' (hit_vtec)
you need the rear L bracket from the 99-00 civic si...stock mounts will work...but i'd change them out for aftermarkets...i have hasport motor mounts on in my ek...all you really need is the driver side mount replaced, and the rear L bracket from the si...other then that, you are good to go...just add wires for knock sensor and vtec/pressure...re-reroute your o2 sensor too...then you are good to go for sure...this is what i did, obd1 b16a into my 98 hatchy
