Help quick car won't start
i went out this morning and moved my car to a different spot. everything was fine. then i come back like 10 minutes later and try to start it again and i get nothing. the key turned to the on position gives me power and the fuel pump comes on, but then when i turn it to start nothing......help
tia
tia
Re: Help quick car won't start (SjCiViCHB)
starter doesn't crank. battery light in the cluster was flickering when i've been starting recently. i have a new battery, i'll try that.
didn't try jumping it cuz it's parked where there really isn't room for another car
[Modified by ahcjar103, 2:48 AM 12/10/2001]
Re: Help quick car won't start (ahcjar103)
it happen once to my sister ....
it was cold ... and my sister went to park the car back inside the garage ...
move it .. turn it off ..
tomorrow morning nth happen ... the motor wont start ...
later i think it probably is .. used up all the battery to crank a cold engine ...
didn't let the alternator to charge it back up ...
a dead battery ...
a dead battery ...
Re: Help quick car won't start (BAR-F1)
the alternator might be bad...my brothers car battery light was flickering too...you might need to check on your alternator...becaus eit's prob not charging up enough...
Re: Help quick car won't start (EG Civic)
the dash lights turn on, the interior light turns on, the fuel pump will go on....all that will happen when the key is in position 2 (on). but when i go to position 3 (start), nothing. no cranks, no nothing. suuuucks.
i have a starter from a friend ad a new battery on my passenger seat. i'm gonna try the starter and alternator first, and then if those don't work swap thebattery.
if you guys have anymore input feel free to let me know. i can move my car till i fix it.
[Modified by ahcjar103, 6:01 AM 12/10/2001]
New User
There is is single wire that goes on the starter..make sure thats in..if its not..NOTHING will happen when u turn the key..happened to my friend.
Re: Help quick car won't start (4g63turbo)
It's the starter... U got a bad starter... Happen to my friend(ITR 2k) once, back then he called me every thursday to fix his car... It happens so that every thursday it breaks down... Change the starter and it should be fine.. Anything else wrong, just post it up...
jorge59la
09-16-2007 06:28 PM
junya16
03-01-2003 07:30 PM
