Need HELP! B16a2 swap 97 ek idles at 2 grand
Old 03-29-2011, 07:35 AM
terronb20ek's Avatar
Default Need HELP! B16a2 swap 97 ek idles at 2 grand
i need some help. i just swapped in a b16 into my ek and i cant get the idle to drop under 2 grand. im using a OBD2b to OBD1 convension harness to my chipped obd1 ecu
Old 03-29-2011, 07:36 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Need HELP! B16a2 swap 97 ek idles at 2 grand
Chipped? You sure it's not your tune/basemap?
Old 03-29-2011, 07:46 AM
its not my ecu grumblemarc because it did the same thing with my stock si ecu.
and TTacous yes it is 99-00 harness and engine. but i dont have the dash harness that plugs into the ecu because my shell is a 96-98 ek. could that cause the problem?
Old 03-29-2011, 07:53 AM
The Grumpiest
Any slack in the throttle cable? Any CELS? Vacuum leak?
Old 03-29-2011, 08:11 AM
hyperblu's Avatar
if you have cruise, make sure its not binding and holding the tb valve open a bit.
Old 03-30-2011, 11:31 AM
well my cel is on but i dont know how to check the codes since i converted it to obd1. and i know im missing a knock sensor. and my throttle body is fine. plenty of slack on the throttle cable
Old 03-30-2011, 11:43 AM
Cortez_h's Avatar
Check the codes like it's obd1. You have no vac leaks?
Old 03-30-2011, 02:06 PM
raidacaipo's Avatar
Check codes then come back and tell us whats wrong.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Also you may have to adjust the TPS sensor
http://www.youtube.com/watch?v=ukPoe5E4Fqg
Old 03-31-2011, 01:03 PM
ok guys i went to read the codes but my dam cel doesnt light up! it wont send me any codes. i used the link raidacaipo posted to check the codes but when i use the blue connector nothing happens. i seriously need some help guys
Old 03-31-2011, 01:24 PM
The Grumpiest
Is the CEL actually working? Bulb present? Burnt out?
Old 04-02-2011, 10:34 AM
yes the cel is working. its on now
still need help guys =(. ineed to get it running rite by honda day
Old 04-02-2011, 10:40 AM
The Grumpiest
Did you at least try adjusting the idle screw?
Old 04-02-2011, 10:44 AM
theres an idle screw?! omg -_-. were is it at?
Old 04-02-2011, 10:46 AM
would dat also cause it to run rich? i pulled the spark plugs the other day and they all were covered in crbon dust. they are brand new not even 100 miles on them
Old 04-02-2011, 10:52 AM
The Grumpiest
I don't know. You never pulled that CEL code. Do that before anything.
Old 04-02-2011, 10:56 AM
idnt kno how. i tried jumping the two wire the cel thread says to jump but my light doesnt flash.
Old 04-02-2011, 10:58 AM
im running an obd2 99 civic si harness with obd2 injectors on a obd1 intake mani wit an obd2b to obd1 step down harness without the 99-00 civic obd2 dash harness
Old 04-02-2011, 04:34 PM
raidacaipo's Avatar
^^ if you can't do a simple task of giving us the codes, then there's really no point in helping.. Try and figure out the codes its the easiest thing to do before you do anything else.
Are you doing it correctly? Did you turn the car on the "On" position? are you jumping the correct connector?
egvtec
08-18-2008 08:20 PM
johnnys_ek9
11-29-2006 08:15 PM
deluzracerx
06-18-2005 07:51 AM
EKB18BPR3
04-04-2005 03:45 AM
Quick Reply: Need HELP! B16a2 swap 97 ek idles at 2 grand
