Ls/vtec question
Old Mar 3, 2009 | 01:53 PM
175Shot4Door's Avatar
Default Ls/vtec question
Ok i have a turbo Ls right now im about to do ls vtec
I WILL ONLY BE REVING TO 7000 until i can get to the machine shop
Question is reving to 7000 will i still need to get a Vtec oil pump or can i use my ls one?
Set up:
B16a2 head
LS block
Arp head studs
OEM Ls headgasket
OEM Ls water pump
OEM Ls timing belt
Old Mar 3, 2009 | 03:57 PM
Silva Bullit DC4's Avatar
Default Re: Ls/vtec question
Is your current LS oil pump a 96 & up pump?
Old Mar 3, 2009 | 04:05 PM
No its a 95. I figured becuase im not changing the redline i wouldent need to shim it but i know vtec uses oil pressure so i need help guys!
Old May 4, 2009 | 10:47 AM
matty413's Avatar
Personally I would just purchase the gsr oil pump. That's if you want reliability man.
Old May 4, 2009 | 11:22 AM
Schister66's Avatar
Man U FTW
It never hurt to upgrade, but if you're on a budget and don't plan to rev higher, i dont see a problem keeping the stock pump
Old May 5, 2009 | 05:52 AM
djxtreme808's Avatar
Wouldn't it suck for you to spin a bearing or lose oil pressure after spending all the time, effort and money to do a ls/vtec conversion and $135 more for a GSR oil pump would have been all you needed to spend more for reliablity. Do it right the first time. Just some advice.
string
Sep 26, 2006 12:31 AM
CaptainMorgan
Oct 9, 2005 09:30 AM
SPOOLED
Dec 16, 2004 08:57 AM
RC000E
Nov 29, 2004 10:35 AM
GRIMEY.STREET.RACER
Jul 20, 2002 05:02 PM
