Engine wont redline
pm for noodz
Engine wont redline
my b16a3 wont redline,it seems to cut off a 7k.i checked all the vaccum lines,the ecu is perfect,dont know what else it could be.im not throwing codes .
pm for noodz
Re: Engine wont redline (mcvtec)
well.my friend has a b16a2 on his eg and his would also redline at 7k.so i dont really know what to do,the car pulls fine.
Re: Engine wont redline (turboteg90)
so what happens at 7k? just cuts off and wont increase rpm? does ur ecu have a 7k redline? first thing id try is swap over an ecu u know has a higher redline
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg90 »</TD></TR><TR><TD CLASS="quote">my b16a3 wont redline,it seems to cut off a 7k.i checked all the vaccum lines,the ecu is perfect,dont know what else it could be.im not throwing codes .</TD></TR></TABLE>
that happened to me too check the wiring! my problem was the temperature sensor
pm for noodz
Re: Engine wont redline (H22Ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">so what happens at 7k? just cuts off and wont increase rpm? does ur ecu have a 7k redline? first thing id try is swap over an ecu u know has a higher redline</TD></TR></TABLE>
so far ive tried a p28,p72,an p30,next is to get one that has no rev limiter
pm for noodz
Re: Engine wont redline (gsrpedro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpedro »</TD></TR><TR><TD CLASS="quote">
that happened to me too check the wiring! my problem was the temperature sensor </TD></TR></TABLE>
how was the temperture sensor affecting the revs/and after you got it fixed it rev to 8k?thanks
