3 wire to 2 wire iacv ?
I need to do the iacv 2 wire plug for my 98 EK4dr with a B-series swap......I went to the junk yard and couldnt find a teggy at all they only had a few eg so i cut the plug of the eg ...Does it matter if the 2 wire iacv plug came off the eg ..Would that plug still work or do i need the one that has the Green and Black wire?
Re: 3 wire to 2 wire iacv ?
You actually have the correct colored wires in the plug you are holding in the photo.
Your 3-wire IACV plug has two wires that match this, along with an orange wire. You will connect the yel/blk to the blk/yel wire, connect the blu/yel wires, and then at the ECU end, move the blu/yel wire to the other side of the orange wire in the ECU plug. Once moved, remove the orange wire and tape over at both ends.
Nicaraguense13
07-28-2008 12:21 PM
