CEL codes after B18B swap! HELP!
After swapping in the engine i'm getting a code 14 (iacv) and 3 (map sensor)...Anyone ever had these problems? The B18B is a obd1 which i swapped it over to my EG...Any help would be appreciated...Thanks
Re: CEL codes after B18B swap! HELP! (D16Z6_turbo)
check the wiring connections to make sure they are plugged in. If you are using the same harness you had before and getting these codes, check the sensors.
Re: CEL codes after B18B swap! HELP! (sinister2c)
I'm using the harness that came with the motor...it's uncut and in good shape...would i have to repin the ecu or anything(sorry first time swapping a motor)?
tomu06
07-09-2012 01:18 PM
