h22 engine misfire
Old 09-29-2010, 06:46 AM
ki11id's Avatar
Default h22 engine misfire
guys pls help i have changed the spark plug lead still not fix the problem. i found misfire on cyl no 1 when i pulled the lead nothing change, so whats the most likely cause the misfire on cyl 1? i just finished h22 conversion into my civic could this be injector wiring problem like not connected properly or lead or spark plug or compresssion..or timing light ,..... help plsss ?
Old 09-29-2010, 06:49 PM
IGOTK22's Avatar
Default Re: h22 engine misfire
You need to specify what's the model of the car the motor is in.....
Old 09-29-2010, 08:10 PM
ki11id's Avatar
civic eg with h22 motor just finishd the conversion, the engine light is not working at all so i cant check the code i am using p28 with o2 + egr removed
Old 09-29-2010, 08:38 PM
EmminoDaGreat's Avatar
check for injector pulse, and compression on the cylinder. If you have both of those then move along to switching that injector w/ another cylinder and see if the misfire moves...
Old 09-30-2010, 08:17 PM
ki11id's Avatar
thx i going to check the injector pulse tmorrow hope i find the problem .. and
did the compression test today read 240psi on cyl 1
Old 09-30-2010, 08:21 PM
SL0WEGG's Avatar
what about the other cylinders? Make sure the colors on the injector wires match up per cylinder as well.
Old 09-30-2010, 08:53 PM
ki11id's Avatar
i havent checked comprss of other cylinders coz the only problem i am having is cly 1. When i checkd the cylnd no 2 3 4, the engine struggle when the lead was pulled
yes it's matched and mine got red black color wire goes to resistor and the other wire which is red with black dots goes to ecu. btw i gonna ceck again tomorrow
bobinyelm
Honda Civic (2001 - 2005)
08-02-2017 09:28 AM
djnikko
03-27-2017 03:53 PM
msdh22
08-09-2010 01:46 PM
93Hammer
12-11-2008 04:10 PM
92hatchs1
02-15-2006 04:35 PM
Quick Reply: h22 engine misfire
