F20B FAQ
When i dyno'd i had the set but my exhaust cam broke not to long ago so now i have the type s exhaust cam in, i have a very shitty video of the car pulling through 1st and 2nd if you want to see it rev to 9k
hay can someone please direct me to a parts list and or directions for the f20b swap for my 97 accord ex coupe i just want to make sure i have the parts and something to read and guild me through before i start the build that be nice thanks
Hey guys, Im about to get an f20b, quick question, do they have a stock oil cooler?
Also when running an Ac compressor from an h22, will my stock eg ac lines bolt into it or will i need to get a full prelude condensor and lines?
Hi to all. Firstly, dose any one know the stock bore of a F20B throttle body? I have a CF4 Accord, auto(for now) and wanting to know some easy bolt on mods. Has great top end alredy but getting there takes soooo long. Maby a B18C5 Throttle body and Headers? Not sure. Help!!! Also, I know the auto comes detuned (good for 180 Hp) If i were to swap the cpu to a manual 1 would that give me the stock 197 hp. Cheers, Mike
Also the small 56-58mm TB it has in auto trim definitely does it (its somewhere in that range) Now the manual trans TB is 62mm which is the same as the ITR TB (they use the same gasket as well) Remember you'd have to either have to port-match your upper plenum for it, or use the upper plenum from the manual version. You can use an H22-based header (I think they actually offer a header for your specific chassis overseas because maybe your chassis has different bracketry but I could be over-analyzing it)
The ecu does not compute the entire hp rating difference. If you havent seen it in this FAQ, the cams your motor has have H22 measurements. The manual trans have cams from the Type S as well as supporting valvetrain (has a high peak HP, more duration and lift) The ecu likely has more aggressive fuel and ignition maps, a higher rev limit to fully capitalize on the extra rpms of the cams and the larger TB feeding more air. That should make up the difference
Cool, thanks heaps! please excuse my ignorance, but what is a plenum? also, i just got my hands on a complete intake manifold off an h22. havent measured the tb yet, but am wonderind if swapping out the tb, rail and injectors will help? or would i just be better off finding a type s head n box. sorry 1 more, will it be safe to just swap with a manual computer on an auto? Or is there no point?
Thanks guys, only been a member for 3 days n have just been reading this 1 thread, every thing i need to know is all here. cheers, mike
I have no idea how it is on your chassis, but the manual ECU wouldnt do you any good if the auto ECU controls your shift solenoids. But I woudnt think you could use it anyway (auto trannies have limitations and if you have a separate box that controls the shift solenoids you wouldnt be able to benefit from it) Try asking around your area to see what you could do about that
Did some research on the F20B Manual and Auto comparing cam part #'s
Euro R/Type S cams are indeed in the Manual SIRT F20B
Manual F20B and Auto both share same valve sizes... exhaust P13 H22
SIRT Manual F20B
Intake Cam 14111-PCB-000
Exhaust Cam 14121-P5P-J00
Intake Valve 14711-PCB-000
Exhaust Valve 14721-P13-000
SIR Auto F20B
Intake Cam 14111-PCB-900
Exhaust Cam 14121-P5M-000
Accord Wagon SIRT H23AVtec 2WD
Accord Wagon SIRT H23AVtec 4WD
Euro R
BB6 SIR Manual
Intake Cam 14111-P5M-000
BB6 SIR Auto
BB4 SI Vtec 5 spd
Intake Cam 14111-P13-000
Exhaust Cam 14121-P13-000
BB4 SI Vtec Auto
SIRT Manual F20B
SIR Auto F20B
Euro R
BB6 SIR Manual
BB6 SIR Auto
BB4 SI Vtec 5 spd
BB4 SI Vtec Auto
I bought a F20B head today of CL for cheap... Owner bought it as manual swap and came with the T2T4 and spun a bearing in the bottom... I mic'd the cams... they are blue tint.
PCB HF-1 1997 Head
Vtec Lobe:
Intake: 1.467"
Exhaust: 1.445"
Anyone with Manual Version mic'd them? Seems like Vtec Lobe is same as Euro R/Type S
I bought it primarly for Valve Springs/Retainers/Cams to swap in a H23AVtec Blue Top that I am ordering soon... which only comes with jdm h22 cams.
The only questionable item was the Throttle Body I mic'd it and was getting about 58/59mm 2.310" on inside of TB near inlet of TB. It was not on the Intake Manifold was seperate however has map on it and no FITV and seems to be the same casting as to what should be on it, no markings to speak of. But cams mic'd out must be a manual...
PCB HF-1 1997 Head
Vtec Lobe:
Intake: 1.467"
Exhaust: 1.445"
f20b uses f23 rod bolts https://honda-tech.com/forums/showthread.php?t=2943838] not sure if this is on here
f20b rods and pistons group buy! https://honda-tech.com/forums/hybrid-engine-swaps-18/bisimoto-f20b-piston-rod-group-buy-2952584/
Just wanted to post up that we just got an F20b engine in and we have been trying to get an alternative timing belt for the PCB OEM belt for a while....but I just took off the timing belt covers and I was trying to figure out what the actual difference was to warrant another tooth on the timing belt. This is what I found:
- Crank pulley timing belt gear is stamped P13 and has 21 teeth just like the H22
- Water pump is stamped "26 tooth P13" just like the H22
- Cam gears are stamped P13
- Tensioner pulley is about 54.5mm diam just like the h22
- Hydraulic tensioner
So here is the kicker!!!! I looked at the printing on the timing belt and it is a "14400-P13-004"...This engine is straight off the boat. So this version of the F20b has an H22 155 tooth belt on it. Anyone seen this before?
