F20B FAQ
Oh ok good to know...
What about the msd external coil, h22 iavc, and stuff... Or can I just throw it in my si and make it work without swapping parts? Reliabilityis number 1!!!
Alright I have some questions. I'm doing a F2B swap(JDM F20B) into a 97 Civic HX and Will be using the stock PCB ECU. So I'm staying OBD-2!
What all needs to be wired (extended?)?
Will I need any special vacuum hoses or fuel hoses?
What radiator hoses are a direct fit? I found the answer somewhere, but couldn't find it again.
What gaskets can I use for the head and block?
What fuel rail is compatible with the F20B studs?
Is there a steel oil pan I can use? Because the aluminum one sucks ***!
Can I use a OBD2 H22 dizzy and plug it right up?
Also is anyone running the Innovative A/C kit with the ESP D series Alt Tensioner? Any Issues?
Sorry, if these have already been answered. But all the info is scattered instead of consolidated!
Read that.
http://www.d-series.org/forums/showc...rbo-build.html
Ok so i came across a problem with my f20b engine i need to replace my crank pulley. I dont wanna bother searching shops for a f20b pulley is there another i can use that will work. I belive the H22A would need to be grinded down to fit properly so thats an option but is there another that would work just as well?
I have a 97 ek with a f20b t2t4 Tranny I'm having huge intake problems and I dont know what to do. It won't accelerate past two grand and I'm getting a fault code but don't have a reader.
K I really need help I am in the middle of my swap and im stuck on tbe wiring for the distributor. The plugs on my harness are only 5wire and the plug on the dizzy is 8. Can any one help me?
https://honda-tech.com/forums/hybrid-engine-swaps-18/converting-f20b-obd2b-small-plug-dizzy-obd1-1957852/
if you read this thread carefully you will figure it out.
so i was changing my timing belt and water pump on my f20b and i noticed that the water pump for the h22 that spindle gear thing is a lot smaller than the one that came with my f20b motor. Will that be a problem? it bolts up just fine.
update
Ok nvm i just checked and the teeth do not line up on the pump, 2 teeth line up and rest are on top of the gear teeth. f20b water pump has 26 teeth the one i got for a 95 prelude (awp 876) only has 19 =\ so looks like i need a water pump from a 97 lude(awp-885) also has 26 teeth. So its on order and im waiting for it to arrive along with a new auto tensioner (one on the f20b was broke)
So this swap is being annoying but i guess it gives me more time to make sure all of the wiring is done correctly.
update
So i searched the thread and i am wondering, for those who opened up this little beast and put it back up;
what head gasket did you use? i read the f22b works, i can get it for dirt cheap. Or the original (12551pcb004) ordered from the usa for triple.
I have currently 2 f20, head off. One was never opened, had original pcb head gasket, the other had another one (have to find what exactly; 95% same except oil drain slightly different in one spot, slightly larger bore(very slightly) and a few coolant passages (around cylinders) are blocked off compared to PCB, and it's not an h22 head gasket.
i am trying to keep this low budjet, it's just for a summer (i hope at least) since i got them for dirt cheap.
Is there a way to use the use the f20b fuel rail? or do I need to use a OBD1 fuel rail and injectors? if possible since the 94 and 95 accord are obd1 would their fuel rail and injectors work? I know they look the same as the 96-97 which is obd2.
I was thinking of using a 91-93 fuel rail but not sure how I would mount the fuel line since the connecter is different and on the other side of the fuel rail.
other than this issue my swap is almost complete =/
just to put it out there, my f20b made 244 flywheel bhp and 173 ftlb.
12.5 cr cr pistons,
eagle rods (b series stroker. 5.862")
rod : stroke ratio 1.69
stock crank, stock bore and stroke.
balance shaft delete kit,
head ports just cleaned up,
superteck guides.
stock valves,
ferrea roller rockers,
ferrea valve springs,
crane roller cams, 272 deg duration, .520" max lift.
crower cam gears,
52mm twm itb's,
plm 4-2-1 header, into 3" straight through system.
8700 rpm limit
12.5 cr cr pistons,
superteck guides.
stock valves,
crower cam gears,
52mm twm itb's,
8700 rpm limit
