Evolution H2B in EG
Old Feb 27, 2007 | 02:00 PM
  #51
sal's Avatar
sal
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">Take a closer look </TD></TR></TABLE>
Old Feb 27, 2007 | 02:44 PM
  #52
high_revs's Avatar
hmmmm...i as well would like elaboration
Old Feb 28, 2007 | 06:01 PM
  #53
lightcrx's Avatar
if the engine sits lower then the tranny sits lower ;x
my hood closes in my crx ;]
Old Feb 28, 2007 | 06:15 PM
  #54
h22apwrdcivic's Avatar
Default Re: Evolution H2B in EG (White_Boy_Racing)
i wanna see who is gonna come out with an updated oil pan now that these kits are on the market, we should be able to keep it from being at such an angle.....hell at the angle it is currently at you would never get all the oil out of the front of the pan with the engine tilted like that. someone with their cad degree get on the horn and make a few for us folks.
Old Feb 28, 2007 | 07:06 PM
  #55
high_revs's Avatar
Default Re: Evolution H2B in EG (h22apwrdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic &raquo;</TD></TR><TR><TD CLASS="quote">i wanna see who is gonna come out with an updated oil pan now that these kits are on the market, we should be able to keep it from being at such an angle.....hell at the angle it is currently at you would never get all the oil out of the front of the pan with the engine tilted like that. someone with their cad degree get on the horn and make a few for us folks. </TD></TR></TABLE>
now here's an idea
  #56
high_revs's Avatar
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">if the engine sits lower then the tranny sits lower ;x
my hood closes in my crx ;]</TD></TR></TABLE>
maybe it sits on an angle
Old Feb 28, 2007 | 07:31 PM
  #57
Default Re: Evolution H2B in EG (h2b_eg8)
take a look at the oil pan pic im talking about from white boy racing on the first page, i think.
as that pan sits you would leave about a half a quart of oil in the pan at every change. do you know what could be lurking in that half a quart??
Old Feb 28, 2007 | 07:35 PM
  #58
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic &raquo;</TD></TR><TR><TD CLASS="quote"> do you know what could be lurking in that half a quart?? </TD></TR></TABLE>
massive shavings you got a valid point....hmm maybe a good magnetic drain plug isnt a bad investment for a h2b'er
Old Feb 28, 2007 | 07:47 PM
  #59
lightcrx's Avatar
Default Re: (h2b_eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">
maybe it sits on an angle </TD></TR></TABLE>
the lower you put the motor/tranny the more the axel angles are off, unless you raise the car up
Old Feb 28, 2007 | 07:52 PM
  #60
high_revs's Avatar
the lower you put the motor/tranny the more the axel angles are off, unless you raise the car up </TD></TR></TABLE>
like crv stats?
i be drivizling my sh*t dumpEd y0!
Old Feb 28, 2007 | 07:53 PM
  #61
massive shavings you got a valid point....hmm maybe a good magnetic drain plug isnt a bad investment for a h2b'er</TD></TR></TABLE>
yeah but that wont get everything. i think moroso's pan is flat on the bottom not sure though...going to look now......
Old Feb 28, 2007 | 07:55 PM
  #62
high_revs's Avatar
yeah but that wont get everything. i think moroso's pan is flat on the bottom not sure though...going to look now......</TD></TR></TABLE>
oh yeah deff not, still wouldnt want that old oil in there, but it does help
Old Feb 28, 2007 | 07:57 PM
  #63
http://www.moroso.com/catalog/...12118
you can see by this link that the moroso isnt that bad. you could possibly even weld a plate in the stock pan to keep oil from sitting that far down??
Old Feb 28, 2007 | 07:59 PM
  #64
lightcrx's Avatar
like crv stats?
i be drivizling my sh*t dumpEd y0! </TD></TR></TABLE>
YEEEEAAAA!!!!! ;x<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic &raquo;</TD></TR><TR><TD CLASS="quote">
if that pan is flat then it would look like ours in a prelude , except back words . if you know what i mean
  #65
high_revs's Avatar
yeah moroso oil pan is by far better on a stock h mounting points...b series mounting points it would still need a little bit more work...
i think we should have some custom h2b oil pans made
Old Feb 28, 2007 | 08:01 PM
  #66
high_revs's Avatar
Default Re: Evolution H2B in EG (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">if that pan is flat then it would look like ours in a prelude , except back words . if you know what i mean </TD></TR></TABLE>
exactly...and ours in a prelude sits on a slight angle, so in order for it to be completely parallel to the ground it would have to be even on a greater angle towards the drain plug...hard to explain
Old Feb 28, 2007 | 09:21 PM
  #67
sal's Avatar
sal
The thing that I noticed by looking at the car in person is that the mounts dont significantly lower the motor much at all. It seems that the main thing causing good hood clearance is more dependent on the angle the mount/mount bracket position the motor. And it doesnt look like the trans is tilted at all. It looks to me like the plate and the driver side mount twist just the motor and leave the trans in the exact position it should be. The angle on the axles look the same as if it had a b-series swap in it. I'll try to get some side by side pics of my car and white_boy_racing's car.
BTW, what h2b kit are you using in your crx?
Old Mar 1, 2007 | 03:55 PM
  #68
lightcrx's Avatar
QS
Old Mar 2, 2007 | 11:00 AM
  #69
sal's Avatar
sal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">QS</TD></TR></TABLE>
That might be why we have mixed opinions. We are talking about two diffent kits.
Also, does you hood shut without hood spacers?
Old Mar 3, 2007 | 08:56 AM
  #70
lightcrx's Avatar
Default Re: (sal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal &raquo;</TD></TR><TR><TD CLASS="quote">
Also, does you hood shut without hood spacers?</TD></TR></TABLE>
yup my hood shuts no spacers here, what opinions are being mixed?
Old Mar 3, 2007 | 09:16 AM
  #71
White_Boy_Racing's Avatar
is that you crx as your avatar? if so then why do you have hood spacers on it?
Old Mar 3, 2007 | 10:21 AM
  #72
turbociviccoupe's Avatar
Default Re: (White_Boy_Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White_Boy_Racing &raquo;</TD></TR><TR><TD CLASS="quote">is that you crx as your avatar? if so then why do you have hood spacers on it?</TD></TR></TABLE>
he did it for the jdm look...no jk...that was before the mod
Old Mar 3, 2007 | 12:24 PM
  #73
sal's Avatar
sal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">yup my hood shuts no spacers here, what opinions are being mixed? </TD></TR></TABLE>
The mixed opinions on how the tranny sits. Since with the QS kit you use b-series mounts right? And with the evolution kit they give you their custom mounts.
Do you have any shots of your engine bay? I'd like to see how it all fits in the crx, thats gotta be a tight sqeeze.
Old Mar 3, 2007 | 12:40 PM
  #74
Default Re: (sal)
yeah but they molded the mounts identical to hasport b series mounts. i asked if you could use the steel innovate's but they said nah they are molded after hasports.
Old Mar 3, 2007 | 01:22 PM
  #75
sal's Avatar
sal
Default Re: (h22apwrdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic &raquo;</TD></TR><TR><TD CLASS="quote">yeah but they molded the mounts identical to hasport b series mounts. i asked if you could use the steel innovate's but they said nah they are molded after hasports. </TD></TR></TABLE>
If they were molded exactly after Hasport's b-series mounts, why wouldnt you be able to use Innovate's steel mounts? They should technically be the exact same mount, just look a little different, right?
