Evolution H2B in EG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal »</TD></TR><TR><TD CLASS="quote">
If they were molded exactly after Hasport's b-series mounts, why wouldnt you be able to use Innovate's steel mounts? They should technically be the exact same mount, just look a little different, right?</TD></TR></TABLE>
are the mounts same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 »</TD></TR><TR><TD CLASS="quote">you can use stock mounts with this kit as well if thats what your asking
didn't know that
</TD></TR></TABLE>didn't know that
didn't know that</TD></TR></TABLE>
now you do
now you do
Wouldn't this require a different motor mount bracket on the DS?
</TD></TR></TABLE>Wouldn't this require a different motor mount bracket on the DS?
If I got this correct, you will be using B mounts in the OEM position? I am curious to see your results as our numbers, and some references indicated clearance issues with the shock tower. Even if, anythings possible and it isn't nothing a hand grinder and a little engunity can't fix
</TD></TR></TABLE>If I got this correct, you will be using B mounts in the OEM position? I am curious to see your results as our numbers, and some references indicated clearance issues with the shock tower. Even if, anythings possible and it isn't nothing a hand grinder and a little engunity can't fix
No offense, but I think this thread just sold me on the QSD 100%. I had some 2nd thoughts just because the evolution kit is more complete, but the QSD uses more OEM parts and I'd rather have OEM then one-off parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">No offense, but I think this thread just sold me on the QSD 100%. I had some 2nd thoughts just because the evolution kit is more complete, but the QSD uses more OEM parts and I'd rather have OEM then one-off parts.</TD></TR></TABLE>
actually the evolution kit can use oem mounts it comes with a block mount so that you can use the driverside b series mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">
Wouldn't this require a different motor mount bracket on the DS?</TD></TR></TABLE>
no...same 3 bolt pattern design
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious »</TD></TR><TR><TD CLASS="quote">
correct...i will be posting pics
</TD></TR></TABLE>correct...i will be posting pics
no...same 3 bolt pattern design</TD></TR></TABLE>
For clarification I'm not talking about the motor mount, I'm talking about the bracket that bolts to the motor.
For clarification I'm not talking about the motor mount, I'm talking about the bracket that bolts to the motor.</TD></TR></TABLE>
yeah i know
yeah i know
::::Spicy hot photos of a Meta-ill EG... cjb92's EASTER EGg!!! CLICK THIS OR YOU WILL REGRET IT!!!::
NIKE SB'd
Jan 21, 2008 06:59 PM
