2000 honda civic dx what engine wireharness to use????
Old 04-18-2008, 10:02 PM
ordny6's Avatar
Default 2000 honda civic dx what engine wireharness to use????
i have a 2000 honda civic dx and i just purchase a 1994 acura integra gsr motor obd1 and i was wondering what engine harness will i need to make this motor work in my car ?some people told me 99-00 ex engine harness some people told me 99-00 si engine harness but i dont know i search but didnt find specific information so any information will help thanks for the noob question
Old 04-18-2008, 10:47 PM
Midori Green's Avatar
Default Re: 2000 honda civic dx what engine wireharness to use???? (ordny6)
use an obd2b vtec harness... which is 99-00 ex or si harness... the si harness being the jackpot but more expensive also when its not all chopped up
Old 04-18-2008, 11:12 PM
GSRcivicDX's Avatar
There is no harness that will be a direct fit. Only the gsr harness is wired for the iab and it wont work, so just modify your harness to have the vtec wires, wires for knock and IAB and change your IACV to the 2 wire setup. Its not that hard to do, you will also have to extend some wires and swap out the internal pickups from your distributor. You will also have to do the CKF bypass trick if you plan on running an obd2 ecu. I just did the same swap on my DX , just make the DX harness look like the one from the GSR.
I found the diagram in this article helpful http://www.d-series.org/forums...21922
Modified by GSRcivicDX at 12:34 AM 4/19/2008
Old 04-19-2008, 07:27 AM
ordny6's Avatar
thanks guys for the info
JNunez87
07-06-2016 05:53 PM
1 Fly SI
11-09-2006 11:51 AM
99'b16at
10-15-2005 09:27 AM
mobrep
01-05-2004 05:31 AM
Quick Reply: 2000 honda civic dx what engine wireharness to use????
