cv joint on eg hatch
Old 07-02-2013, 10:31 AM
kiko_eg-hatch's Avatar
Default cv joint on eg hatch
Can sum1 help me out n tell wich cv joint I. Should buy for my eg hatchback. It has b18c swap. I bought sum 97 integra shatf they look shorted then the 1s I took off not. Sure if Igot the wrongs or If the store gave the wrongs
Old 07-02-2013, 10:33 AM
skill178's Avatar
Default Re: cv joint on eg hatch
Do you have the half shaft?
From my experience you always match the axels to the tranny
Old 07-02-2013, 01:11 PM
sidewayz6.6's Avatar
This. Also, see if there is a difference in axles between the integra ls and the integra gsr.
Old 07-02-2013, 08:18 PM
Old 07-02-2013, 08:54 PM
The half shaft is on the driver's side rite cause im swaping out the passenger side shaft
Old 07-02-2013, 08:58 PM
Im finna see 2mmor wen I go 2 the auto parts cuz I told them it was for the gsr n not ls
Old 07-02-2013, 09:02 PM
slowDB7's Avatar
you can check online if they are the same check autozone and see if part numbers are the same...or check hondapartsunlimited.com to see if they are the same
Old 07-03-2013, 05:12 AM
kyden's Avatar
90-01 integra passenger side axles are the same.
fin781
12-12-2009 05:29 AM
OverBoostDemon
11-03-2009 09:58 AM
DB1_559
08-06-2005 04:27 AM
hondaguyexsi
06-23-2005 08:01 AM
brandond
01-17-2005 09:49 AM
Quick Reply: cv joint on eg hatch
