Will pr3 ecu be compatible with my b16a sirI
Old Jun 12, 2003 | 04:21 PM
HybridIntegra's Avatar
Default Will pr3 ecu be compatible with my b16a sirI
I have a b16a obd0 motor in my 1990 integra. Will the pr3 chip work?
Old Jun 12, 2003 | 04:58 PM
JDMCivicEF9's Avatar
Default Re: Will pr3 ecu be compatible with my b16a sirI (HybridIntegra)
If its the PR3 ECU, then it should work. But I've never heard of a PR3 chip before. Tell us more about your PR3 chip. Where did you get it anyways?
Old Jun 12, 2003 | 05:04 PM
bryant's Avatar
Default Re: Will pr3 ecu be compatible with my b16a sirI (JDMCivicEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCivicEF9 &raquo;</TD></TR><TR><TD CLASS="quote">If its the PR3 ECU, then it should work. But I've never heard of a PR3 chip before. Tell us more about your PR3 chip. Where did you get it anyways?</TD></TR></TABLE>
lol, yeah sounds fishy to me too. for your B16a use PWO or PR3 ECU.
Old Jun 12, 2003 | 06:10 PM
Patch's Avatar
Default Re: Will pr3 ecu be compatible with my b16a sirI (Bryant)
If you're asking if you can put a PR3 chips in your stock Integra computer to run the B16a, the answer is no. You need a PR3 or PW0 computer.
Old Jun 13, 2003 | 12:43 AM
Oh its my mistake for calling it a pr3 chip, I meant the whole ecu. Thanks for the info guys
Old Jun 13, 2003 | 12:45 AM
Default Re: Will pr3 ecu be compatible with my b16a sirI (CRX PAT)
Will the pr3 ecu plug in directly to my stock wiring harness, or do I have to make any alterations to the harness for it to work?
Old Jun 13, 2003 | 02:42 AM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Will the pr3 ecu plug in directly to my stock wiring harness, or do I have to make any alterations to the harness for it to work?</TD></TR></TABLE>
Yes, The PR3 or PW0 is a non-OBD (or OBD0) Vtec ECU. It is plug and play!
Old Jun 13, 2003 | 04:35 AM
Default Re: Will pr3 ecu be compatible with my b16a sirI (turbogixxer)
Thanks a lot, you guys have been alot of help.
Old Jun 13, 2003 | 05:16 PM
untitled's Avatar
you have to plug in the ecu and then run you vtec wires. for pr3 there should be 4 wires. solenoid, pressure, ground, knock sensor. if it is pw0 there is no knock sensor. so if you did the swap and are thinking you can just put the pr3 ecu in and youll get vtec. you wont. but in a sense it is plug and play.
Old Jun 15, 2003 | 12:01 AM
Default Re: Will pr3 ecu be compatible with my b16a sirI (88crx91integra)
So what would I need to do to hook up the vtec if I swaped the ecu? What does running the vtec wires consist of?
Old Jun 15, 2003 | 05:44 AM
Vtec solenoid is A8, Vtec pressure switch is B5 (then the other wire is ground), Knock sensor is B19.
KDvtec5757
May 22, 2008 09:09 PM
jeremycrxb16
16
Nov 4, 2007 07:14 PM
xDicktonesx
May 12, 2005 08:46 AM
GeeSeeR
Sep 18, 2001 06:30 PM
