oil leak from back of b18c head
Old Mar 25, 2007 | 11:07 AM
shifts's Avatar
Default oil leak from back of b18c head
got the head resurfaced/port&polish/3angle valve job/valve adjustment n installed new head gasket w/arp head studs. when we started it oil started to leak from the back of the head through the head gasket. so we took everything off n reinstalled it. tried it this mornin n once again oil leak. we took the head off n saw that the oil is leakin from where the hg isnt sealin to the head. we r thinkin that when the head was resurfaced it may n off a tad bit. ne suggestions? hg? head job?+
edit: we had it resurfaced AGAIN n still produced a leak.
Modified by shifts at 12:10 PM 3/31/2007
Old Mar 25, 2007 | 02:45 PM
shifts's Avatar
Default Re: oil leak from back of b18c head (shifts)
up.
Old Mar 28, 2007 | 05:20 PM
D_CRX_Si's Avatar
It will prolly blow on start up and i doubt you put spark plugs in it. :D
Old Mar 31, 2007 | 09:09 AM
shifts's Avatar
up up we go.
Old Apr 2, 2007 | 05:48 AM
shifts's Avatar
mornin.
Old Apr 2, 2007 | 06:00 AM
stumpyf4's Avatar
Check the dowel pins, sometimes these need to be shortened when the block is decked and the head is resurfaced. If they're too long they will keep the head from sealing.
Old Apr 2, 2007 | 06:08 AM
shifts's Avatar
Default Re: oil leak from back of b18c head (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Check the dowel pins, sometimes these need to be shortened when the block is decked and the head is resurfaced. If they're too long they will keep the head from sealing.</TD></TR></TABLE>
how would i go about checkin for that? i think its the upside down gasket...ive read two other post n they leak the same place. cept not sure how we manage to put it upside 3-4 times that weve tooken it apart n tried to figure out as to what it is.
Old Apr 2, 2007 | 10:40 PM
stumpyf4's Avatar
If you have a set of calipers, use the depth probe to check the bore depth in the head and the block. Add these measurements up and make sure your dowels are shorter.
Edit: need to take account the thickness of the head gasket.
Old Apr 3, 2007 | 06:49 AM
dbiker207's Avatar
i had a similar problem, i forgot to reinstall one of the oil plugs (allen key) into the head by the intake manifold. if its your headgasket then u would have low compression so check that. hope this helps
Old Apr 3, 2007 | 07:23 AM
sr20b13's Avatar
i've seen it before
Old Apr 3, 2007 | 07:26 AM
shifts's Avatar
Default Re: oil leak from back of b18c head (dbiker207)
im pretty sure its the headgasket bein upside down. it would start up fine w/perfect timin but then it would lose rpms as if it was the compression.
Old Apr 3, 2007 | 12:15 PM
shifts's Avatar
w00t for Hybrid-Performance.com.
Old Apr 5, 2007 | 07:27 AM
shifts's Avatar
it was the gasket . now to figure out the codes.
Old Apr 5, 2007 | 05:15 PM
integratee's Avatar
let us know how it runs
Old Apr 6, 2007 | 02:33 PM
D_CRX_Si's Avatar
Runs good despie IACV problems. ut its well taken care of
thewrai6th
Oct 12, 2009 03:45 PM
alupso
Feb 27, 2008 01:09 PM
ac_attak
Jan 4, 2007 05:11 PM
solofthesouth
May 8, 2006 06:47 PM
