Compression guestimates
Old Aug 12, 2006 | 05:19 AM
migs's Avatar
Default Compression guestimates
Well, I finally put together my new bottom end. The ingredients consist of:
1) used - C5 block (bored)
2) LS crank
3) LS rods
4) P73 pistons 81.25
ITR girdle and windage tray etc
I bought the block from somebody who spun a bearing but the top of the deck had some bruises that had to be machined off. The top of the deck was shaved by 0.008" I am going to use an OEM gasket. What would you guess my compression maybe?
Edit: Stock ITR head
Modified by migs at 9:19 AM 8/12/2006
Old Aug 12, 2006 | 05:51 AM
len's Avatar
len
Default Re: Compression guestimates (migs)
Your compression = 0
No head = no compression.
Old Aug 15, 2006 | 11:47 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Compression guestimates (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">Your compression = 0
No head = no compression. </TD></TR></TABLE>
lol
Old Aug 15, 2006 | 05:59 PM
Circuit Star-29's Avatar
Should be right around 11:1. A correct "Ls/vtec" setup...it should rip.
Note: You'll have to plug the oil squirters with some bolts. The crank will hit. If you're worried about heat get a jet coating on the top of the pistons.
Old Aug 15, 2006 | 06:22 PM
migs's Avatar
Default Re: Compression guestimates (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Should be right around 11:1. A correct "Ls/vtec" setup...it should rip.
Note: You'll have to plug the oil squirters with some bolts. The crank will hit. If you're worried about heat get a jet coating on the top of the pistons.</TD></TR></TABLE>
I bent the oil squirter a little bit and it clears.
How did you get that calculation?
Old Aug 15, 2006 | 07:28 PM
slo blue's Avatar
Compression ratio: Volume of the cylinder, piston dish and head dish and
headgasket from top to bottom of the stroke, divided by the head, piston,
and headgasket volume or:
bore(in.) x bore(in.) =__ x .7854 =__ x stroke (in.) =__/ .061=__cc of
cylinder + (head cc +piston cc + headgasket cc) / (head cc+ piston
cc+headgasket cc) = compression ratio
Old Aug 16, 2006 | 11:22 AM
migs's Avatar
Default Re: Compression guestimates (slo blue)
Ended up welding the holes shut. There is a concern about the rigidity of the squirter since we bent it.
Old Aug 16, 2006 | 07:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Ended up welding the holes shut. </TD></TR></TABLE>
sAVaGe, FTW...HAHAH...
masquzy1080
Nov 23, 2007 08:45 PM
PinkMaggit
Dec 11, 2005 10:56 PM
CALM_AS_A_BOMB
Mar 14, 2005 05:34 AM
CRneXt
Sep 27, 2003 07:56 AM
98 Ek LsVtec
Feb 7, 2002 09:25 PM
