B20VTEC Question....
Old 12-11-2003, 02:56 PM
Mag00n's Avatar
Default B20VTEC Question....
I have a Del Sol VTEC(Factory B16A3). I'm considering swapping in a b20 block and using the head and tranny off my A3(as well as my timing belt and water pump) My question is, from the research I've done, I'm 99% percent sure the mounts from my b16 will work, but will my axles hold up? I'm guessing they should be ok since they are bseries axles? I plan on staying N/A. And, if that is the case, then this should be a fairily easy and inexpensive swap(b20block) considering I'll have my b16a3 to take everything that I need off of it? Also, will my stock ecu be compatible? I think it should as well.....I have done much searching but most people are swapping b20's into del sol S and Si...Thanks for the help
Old 12-11-2003, 03:58 PM
tommyL's Avatar
Default Re: B20VTEC Question.... (sickSOLvtec)
I recently went from a 94 del sol b16 to a b20vtec and your assumptions are true. Mounts are the same, tranny swapped over (in my case a y1 cable), axles are fine. My friend who assembled the motor and swapped it into my car, put down 180/129 (you will probably realize about 160-65/125ish if you stick with stock head/cams) with a pr3, adjustable fpr and itr cams. He thought the usdm p30 did a little better job of running the motor now that it's in my car. The fpr is set at 48 psi.
I have an s100/p28 that has a b20vtec basemap and we tried it without tuning. The p30 worked much, much better. Won't be using the hondata p28 til I can get to a dyno with a good tuner.
I have to admit, I'm a little leary of that 8000+rpm rev limit of the p30 with my stock bottom end. I find myself shifting well before, in the 7-7.5 range, but gawd the torque down low and mid-range... totally worth it. There are quite a few people on this board who seem to think that 8000 rpm is not a problem.
Disclaimer: I just realized that you actually have a del sol vtec, I'm driving a crx but it seems logical that since the b16a3 was replaced in my car by the b20vtec, the same would apply to yours.
Old 12-11-2003, 05:02 PM
Mag00n's Avatar
Default Re: B20VTEC Question.... (tommyL)
Thanks man, good info
Old 12-12-2003, 01:30 PM
Crazy Honda Guy
Deetz's Avatar
You won't be able to use a B16 timing belt on a B20 block as the block stands higher.
Old 12-14-2003, 06:05 PM
blueturbo4door's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">You won't be able to use a B16 timing belt on a B20 block as the block stands higher.</TD></TR></TABLE>
true. the deck height is 8mm taller. go with a type r water pump, oil pump, and timing belt! also if you have the money invest in some good rods or at least arp rod bolts, and a z10 block girdle.
DelSol-B18
04-14-2014 07:07 AM
KodSol
03-17-2007 06:32 AM
SOLvtec
09-12-2006 03:15 PM
Mag00n
16
12-13-2003 11:25 AM
rioninja
06-15-2001 11:54 AM
Quick Reply: B20VTEC Question....
