b18c1
Old Jan 4, 2002 | 04:41 AM
17secondcivic's Avatar
Default b18c1
i'm putting a b18c1 in my 1997 civic hx and i'm wondering how to go about wireing it up. the motor's from a usdm 1994 teg gsr.
[Modified by 17secondcivic, 1:53 PM 1/4/2002]
Old Jan 4, 2002 | 09:21 AM
jdm_latino's Avatar
Default Re: b18c1 (17secondcivic)
have you done you reaserch on your swap
i dont know if you should put an older motor in your car
it may not be legal in your state.. you should check into it
just tryin to help.....good luck
Old Jan 4, 2002 | 09:25 AM
Spade's Avatar
Default Re: b18c1 (jdm_latino)
Correction, you will not be legal in your state.
Old Jan 4, 2002 | 11:02 AM
Trey's Avatar
25 Year Member
Default Re: b18c1 (Spade)
Basic 6gen wiring info here:
http://www.jspectuning.com/6gen/
If you use your OBDI ecu then you'll need the OBDII to OBDI ecu converter harness since the plugs are different.
You should stay with an OBDII motor though.....
Old Jan 4, 2002 | 11:16 AM
sloppy_seconds's Avatar
Banned
Default Re: b18c1 (Trey)
trey, can't he just wire up the motor and get a harness converter? then just plug in the new harness and the ecu? (i just FEEL that im wrong with that statement!)
--justin
Old Jan 4, 2002 | 02:12 PM
Tragedy's Avatar
I know in the State of California it is illegal to put a motor that is older than your chassis into your car. I don't know about Connecticut though.
Good Luck
Old Jan 4, 2002 | 02:14 PM
DragII's Avatar
Default Re: b18c1 (Tragedy)
I believe cali is the only state w/ that law.
Old Jan 5, 2002 | 10:06 AM
Default Re: b18c1 (AntGonch)
there is no law in c.t ...... what would i have to do to go about wireing this motor up in my car
Old Jan 5, 2002 | 11:19 PM
Jason S.'s Avatar
Default Easier Way...in a way
Here is what I think would be far easier for you than all of that ECU harness adapter stuff. Why not just swap the distributor, engine wire harness, alternator, and a few other things with OBD2 equiptment. Then you dont have to wire anything too crazy since your chassis is OBD2 already. You will only have to wire Vtec and Knock Sensor. My TypeR swap was wired OBD1 for a while to avoid wiring headaches, but it was really easy to change everything to OBD2 on the motor. Just a thought.
Jason S.
619ej8
Engine Management and Tuning
Jan 18, 2013 08:41 PM
96GeeSR
Sep 14, 2011 03:13 PM
gsrstick
Nov 3, 2008 05:57 PM
orientalgunz_00
Jul 13, 2006 02:38 AM
Black HB
Sep 10, 2003 10:38 AM
