B16a Vaccum Lines
Old 01-24-2003, 10:30 AM
Turbo88hatch's Avatar
Default B16a Vaccum Lines
Ok i need to know how to run my vaccum lines correctly so my B16a will run right in my 88 hatch.I heard that you have to T one of the lines off because in Japan the SiR comes with a pressure regulator solenoid cut-off and a purge cut-off on the MAP sensor.I've also heard that you can use the MAP off of a 90-91 integtra but i dont know how true this is.I just want a definative answer to my problem so i decided to ask the best............................thanx!!!!!!!!!!
Old 01-24-2003, 10:37 AM
Jeff C's Avatar
Default Re: B16a Vaccum Lines (vegitastorm)
https://honda-tech.com/zerothread?id=293057
fuel..
01-19-2012 04:02 PM
Asahi
05-17-2003 03:37 PM
mraudio13
10-09-2002 11:23 AM
Quick Reply: B16a Vaccum Lines
