rear disc brake swap for an EG
i have the rear discs ready to go on but i am wondering what kind of brake proportioning valve i would need. right now i have rear drums and i have a 30/30. (which leaks, this is the reason i am doing this) WILL A 40/40 OFF AN INTERGRA WORK?
Re: rear disc brake swap for an EG
Nice to know, I'm going to swap out the drums on my EG.
I have a european EG4, from what cars can I take a rear trailing arm from ?
Just the Integra 94-2001 ? Not many of them here in Iceland, can I use a arm from
a EK Civic 1996-2000 ? My guess is no, just wanted to check
u can use any trailing arm with rear disc from these years
88-00 civic
90-01 integra
and the e-brake lines will need to be from a Si civic or else integra lines may be too long
88-00 civic
90-01 integra
Teg lines fit perfect I just did this swap, I used Rear disc off a 94-01 Teg and everything bolted right up. But on my old hatch i used the rear disc from a 90-93 teg and the line was waaaaay to short I had to go pick up some lines from a 94-01 teg from the parts yard and solved the problem
purple98ek
05-22-2007 07:33 PM
1CiViC1
02-15-2004 06:55 PM
