Wheel fitment
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
I know this is a major topic but before you go flaming me. I searched the forum and paged back through the archives aways and couldn't find anything. I am thinking about getting Work Vssx for my 02 S2000. I was going to run a 17x8 1/2' in the front with a 54 and a 17x9 with a 60 in the rear I just need to know if that will fit without any major body work. Thanks for all your help.
the wheels that you have chosen is a very nice set up IMO.
your best bet is to run the following:
215-45-17 front
255-40-17 Rear
You should actually be able to get away with stock fenders also, so no rolling of the fender is needed. That is unless you want to run a 265-40, then rolling of the fender is needed for MAXIMUM clearance.
You can also try and push a 225 under the front too, but make sure you run some negative camber if you plan on to.
but again, if you want to keep it safe, run the above size and fitments of:
215-45-17 front
255-40-17 Rear
215-45-17 front
255-40-17 Rear
215-45-17 front
255-40-17 Rear
![](https://honda-tech.com/forums/images/smilies/emsmile.gif)
![](https://honda-tech.com/forums/images/smilies/emwink.gif)
![](https://honda-tech.com/forums/images/smilies/emsmilep.gif)
Thanks for all the help I thought they would fit but I just got the car, but I had researched the wheels before because I had been lookin at s2000s for awhile. But I couldn't find any concrete evidence that they would fit. Coming for a Nissan 240sx to this is a whole different ball game to me. Everything is different.
VS-xx don't look as good in 17 as they do in 18.....same with the bbs LM...i dunno why guess cuz the spokes are shorter?
Both very nice wheels however.....
